Can you simplify 2e^(ln12/2) and 2e^(ln6/2)?
In summary, the problem states that you need to find the volume of a solid when it is revolved around the x-axis. The washer method was used to find the volume, but it was incorrect.
jrjack
111
The full problem is y=e^(x/2) and y=e^(-x) revolved around the x-axis, from [ln6,ln12].
The part I'm struggling with is evaluating 2e^(ln12/2) and 2e^(ln6/2).
I am just reviewing for my Calculus 1 final.
[tex]2e^{(ln12/2)}[/tex]
[tex]2 e^{(1/2)(ln12)}[/tex]
[tex]2 (e^{1/2}), e^{ln12}=12, and 2(12)e^{1/2}?[/tex]
Well you can easily show that e^(lnA) = A. So you can use that result as is.
The problem is [tex]e^{(\frac{ln12}{2})}[/tex]
not
[tex]e^{ln\frac{12}{2}}[/tex], that would be e^(ln6)=6
I have a full equation that looks like this:
[tex]\pi((2e^{\frac{ln12}{2}}+e^{-12})-(2e^{\frac{ln6}{2}}+e^{-6}))[/tex]
I doubt that you have stated the full problem ?
What are you finding? Volume, Area, ... ?
What is being revolved around the x-axis ?
Sorry, maybe I have made a mistake in my prior work. (this may need to be moved to the calculus section)
The problem states: Use the washer method to find the volume of the solid when the region bounded by y=e^(x/2) and y=e^(-x), x=ln6, x=ln12, when the region is revolved around the x-axis.
So I started with:
[tex]\int_{ln6}^{ln12}\pi(e^{\frac{x}{2}}-e^{-x})dx[/tex]
[tex]\pi(2e^{x/2}+e^{-x})|_{ln6}^{ln12}[/tex]
[tex]\pi((2e^{\frac{ln12}{2}}+e^{-ln12})-(2e^{\frac{ln6}{2}}+e^{-ln6}))[/tex]
[tex]a^{\frac{1}{2}}=\sqrt{a}[/tex]
and
[tex]\left(a^b\right)^c=a^{bc}[/tex]
using these two rules for indices, you should be able to answer your question.
Thanks, so...
[tex]2e^{\frac{ln12}{2}}=2\sqrt{e^{ln12}}=2\sqrt{12}[/tex]
[tex]=4\sqrt{3}[/tex] and
[tex]2\sqrt{e^{ln6}}=2\sqrt{6}[/tex]
giving me:
[tex]\pi((4\sqrt{3}-\frac{1}{12})-(2\sqrt{6}-\frac{1}{6}))[/tex]
[tex]\pi(\frac{1}{12}+4\sqrt{3}-2\sqrt{6})[/tex]
But that was wrong, and I am unsure how to get the correct answer.
How does that become [itex]\frac{575\pi}{96}[/itex]?
jrjack said:
giving me:
No, this isn't true.
[tex]-\frac{1}{12},-\frac{1}{6}[/tex] here is mistake.
Hm, I checked this in one program, and it isn't true also.
So I started with:
Using the washer method to find the volume of the solid when the region bounded by y=f(x) and y=g(x), x=a, x=b, is revolved around the x-axis, (Assumes f(x)>g(x) on the interval [a,b].) results in the following integral:
[itex]\displaystyle \int_a^b\pi\left((f(x))^2-(g(x))^2\right)\,dx[/itex]​
You failed to square the two functions.
Man do I feel like an idiot. Thanks for pointing that out.
Related to Can you simplify 2e^(ln12/2) and 2e^(ln6/2)?
1. What is the value of e^(ln12/2)?
The value of e^(ln12/2) is 12.
2. Why is the log function used in this expression?
The log function is used to isolate the exponent, ln12/2, which can then be evaluated using the natural logarithm function.
3. What does ln12/2 represent in this expression?
ln12/2 represents the exponent or power that e is raised to in order to equal 12.
4. How is the log function related to the natural logarithm function?
The log function is the inverse of the natural logarithm function. In other words, the log function "undoes" the natural logarithm function, and vice versa.
5. Can this expression be simplified?
Yes, e^(ln12/2) can be simplified to just 12.
