Logarithmic Mean Temperature Difference
6 replies · 7K views · last reply
member 392791
I am confused as to which streams I should use for the log mean temperature difference. I am pretty sure it should be the difference in temperature between the two streams on the same side, so I think it's
(700-450)-(1100-960) / ln [(700-450)/(1100-960)], but I am not sure.
The term wasn't well defined, and my search on wikipedia gave the definition as ''The LMTD is a logarithmic average of the temperature difference between the hot and cold streams at each end of the exchanger.''
This is too vague, which end of the exchanger??
  • Schematic of a heat exchanger as a rectangular box with two streams: stream 1 enters at T1,in = 450°C and leaves at T1,out = 960°C; stream 2 enters at T2,in = 1100°C and leaves at T2,out = 700°C.
I am confused, because the only reason I know it had to be that was because I would get a negative logarithm if I did it the other way. Suppose it was such that I didn't get a negative number in the logarithm either way that I subtracted it, then how would I do it??
You take hot temperature minus cold temperature at one end of the heat exchanger, and hot temperature minus cold temperature at the other end of the heat exchanger. How you do things after that doesn't matter.
