Looking for a 12VDC motor with low RPM
  • Thread starter Thread starter may ki
    Motor Rpm
A user seeks a 12V DC motor with low RPM (3-10) for a robot's color wheel but finds most available options exceed 3000 RPM and are too noisy. Suggestions include using gear motors, stepper motors, or servo motors, with specific recommendations for quiet motors from printers or cassette players. The discussion also mentions using a square wave to control motor speed effectively. The thread was closed due to a spam connection, but participants provided valuable insights. Overall, the conversation highlights the challenges of finding a suitable low RPM motor while exploring various alternatives.
may ki
I'm looking for a motor that will drive a colorwheel inside a robot. All of the 12v/DC motors I have discovered so far have significantly higher RPMs (3000+) than I require. I would prefer something that runs quietly between 3 and 10 RPM. I looked online and found a few gear motors to try, but the noise is similar to a power screwdriver going on high. There is a lot of transmission noise that cannot be muffled.
I decided to ask a question here because I am a complete electronics novice. I'm unsure of the possibilities available or whether such a motor even exists.
Low torque ? Perhaps a plastic gearbox, or a stepper motor...
Likes russ_watters and berkeman
What the heck, you already have a motor/gerabox you can't use, so try adding some oatmeal to the gear box. (dry, uncooked oatmeal)
If size is not a problem, a motor/gearbox that operates the windows in a car.
Or a servo motor as used in model airplanes or boats.
Likes russ_watters
A motor from a computer printer is quiet in operation. Alternatively, a cassette motor is very quiet and reliable. You can make a motor turn slowly by driving it with a square wave having a mark space ratio which differs slightly from 50%. Use a low frequency, such as 25 Hz, so the motor armature is shaken slightly, as this avoids stiction.
Unfortunately, a connection between the OP and a spammer was found, so I'll close this thread now. Great responses by you folks to the question! :smile:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
