Looking for a Tiny, Low RPM Motor for a Digital Guitar Tuner? Help Needed!
  • Thread starter Thread starter programmer
    Motor
A user is seeking a tiny, low RPM motor for a digital guitar tuner that can tune strings with minimal touch. The ideal motor should operate on 5V, be reversible for tuning adjustments, and come with guidance on motor basics. Stepper motors are suggested due to their controllability, though they require additional equipment and may not operate efficiently at 5V due to power limitations. The discussion highlights the need for a low-speed, high-torque motor to handle the tension of guitar strings. Overall, finding a suitable motor that meets these specifications is crucial for the project’s success.
programmer
Hello all. As a Digital project, I'm trying to construct a digital guitar tuner that will actually tune the guitar for you, all you have to do is put the device on the tuner and pluck a string. My problem is I'm not very mechanically inclined...
Does anyone know a tiny hobby motor with a very low RPM (it only takes the slightest touch usually to tune a guitar). It'd be nice if it ran off of 5V (so I can get the digital components and motor off the same supply), reversibile (for tuning up and down), and some kind of guide for motor basics?? If this exists can you point me in the right direction?
If ever there was an application for a stepper motor...The controlability is exactly what you are looking for. However, the drawback is the equipment required to operate one.
http://en.wikipedia.org/wiki/Stepper_motor
http://www.eio.com/stepindx.htm
http://www.solarbotics.net/library/pdflib/pdf/motorbas.pdfYou definitely would want something low speed and high torque. I can't say that I have ever heard of one running off of 5V though. You wouldn't have much power available to turn a tuning peg that has a tensile load due to string tension. I think you may have to concede that design point.
stepper motor are easiest to control though the interface is a bit complex
Thanks, looks like exactly what I was looking for! Appreciate it!
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
