How Big Should the Airflow Hole Be for Smooth Liquid Pouring from a Juice Box?
  • Thread starter Thread starter Ytisulu
Ytisulu
If you pour liquid from a regular juice box, and there is no air flowing into the container, then the liquid will squirt when it exits the open lid. But if you make a hole on the opposite side of the lid, so there are two holes. The original hole for pouring the liquid, and the second hole to create a flow of air into the container, the stream of the liquid will then be more smoothly and reduce the squirting.
My question is whether there is any equation to calculate how big the hole for the airflow must be, before the stream of the liquid leaving the juice box will be smoother, and not squirt. I've tried researching this for quite some time, but I've not find anything relevant.
Hi Ytisulu, welcome to PhysicsForums! Since this is the Homework forum, we need you to do a couple things before we can help you out with this problem. Specifically, we need to know exactly what the problem statement is, and what things you've tried with it so far. Once you've done that, we can help you with whatever parts you're stuck on.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
