Lorentz Transformation on a Wave Function
bobc2
Let's say an observer A in his rest system has a wave function for an electron double slit experiment (psi function of x and t). Would there be any inconsistencies between QM and relativity coming out of a QM analysis performed by observer A and some other observer, B, who is moving at relativistic speed relative to A (B applies Lorentz Transformation on the wave function)?
No, I don't think so. Dirac's equation for the electron is relativistically invariant.
Thanks for the comment, Mentz114. Of course you are certainly right about Dirac's equation being relativistically invariant.
As I was pondering Roger Penrose's concept of the electron wave function representing the objective reality of the electron (as opposed to the collapsed wave function), I was wondering about any implications coming out of Lorentz transforming the actual wave function for different observers. I had never thought about applying a coordinate transformation to a wave function (maybe I was absent or sleeping in class the day the prof mentioned it) and thought I'd probe for any ideas here before launching into it (of course we would be working with Hilbert space).
Phase is preserved by LT in any wave, because a change in the interference pattern as seen by different observers could lead to a causal paradox ( being a scalar it is automatically invariant, of course ).
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
