Mangoes
- 92
- 1
I'm being asked to derive the velocity transformation between vy and vy' and my result isn't exactly matching my goal but I don't know what I'm doing wrong. It's an introductory modern physics course and we're covering special relativity.
Assume a reference frame S' moving in some constant velocity vx with respect to a stationary frame S. Since time isn't synchronized (dt ≠ dt') then the velocities vy and vy' aren't the same even though y and y' aren't being affected by length contraction (y = y'). The aforementioned statement isn't necessary for the following but I'm just wondering if the above is a correct statement.
Anyways, this is my logic:
Since y = y', dy = dy'. I want to know dy/dt'. From the chain rule:
\frac{dy}{dt'} = \frac{dy}{dt}\frac{dt}{dt'}
Letting λ = \frac{1}{(1 - (v/c)^2)^{1/2}}, the Lorrentz transformation for time is:
t' = λ(t - \frac{vx}{c^2})
Since there is no fundamental difference between two inertial reference frames, the inverse transformation must be of the same form:
t = λ(t' + \frac{vx'}{c^2})
In differential form,
dt = λ(dt' + \frac{vdx'}{c^2})
Now differentiating the above wrt t',
\frac{dt}{dt'} = λ(\frac{dt'}{dt'} + v\frac{dx'}{dt'}/c^2)
\frac{dt}{dt'} = λ(1 + vv_x'/c^2)
Going back to my original goal:
\frac{dy}{dt'} = \frac{dy}{dt}\frac{dt}{dt'} = v_y\frac{dt}{dt'}
\frac{dy}{dt'} = v_y(λ(1 + vv_x'/c^2))
...which is wrong. Where am I going wrong with this? Would appreciate some clarity.
