Plastic Photon
- 138
First, MacGuyver uses a pine tree shaped airfreshner to cut the rope binding his hands behind a chair.
NExt, he takes a tube sock to slide down a metal wire from about 2 stories to the ground.
Last, he takes a paper clip, ball point pen, rubber band, a few other items and turkey bastor to start a diesel truck.
I am wondering, is it really possible to use an air freshner to cut through any sort of rope that would be used to hold together a man's hands behind a chair apparently against his will?
Next, it seems unlikely that a tube sock would cause enough friction to slow a man, let's say 185 pounds, down enough to where he does not break his legs after sliding down at about a 50 degree angle two stories up?
And can you really jump start a diesel engine with a paper clip, ball point pen, ruber band and turkey bastor; all before the building you were in blows up?
The answer is of course: only if you are McGuyver.
