Maclaurin formula: finding a delta for a given error
Telemachus
Approximate the function f(x)=\sin(x) using the corresponding Maclaurin polynomial: P_5(x), in a bound \epsilon(0,\delta). Determine a value of \delta>0, so that the rest R_5(x) verifies |R_5(x)|<0.0005 for all x\in{\epsilon(0,\delta)}
Well, the first thing that puzzles me a bit is that the order for P_5 and R_5 is the same. I assume that it is a mistake, and that the polynomial must be P_4, or the rest R_6. I have chosen to leave the degree of the polynomial as it was and turn up one grade to the rest.
So I have to find a delta for which any value within the environment (0,\delta) is less than the error 0.0005
So I did:
R_6(x)=|\displaystyle\frac{\sin(\alpha)x^6}{6!}|<0.0005 0<\alpha<x
So I must find x:
R_6(x)=|\sin(\alpha)x^6|<0.36 0<\alpha<x
I must find x that satisfies the equation: \sin(x)x^6<0.36
I don't know how to go ahead.
Bye there.
I think you're just getting confused by the notation. The usual notation is
R_n(x) = f(x)-P_n(x)
The remainder term turns out to depend on xn+1 and f(n+1)(x).
So I did:
So I must find x:
Bye there.
Hint: Use the fact that x ≥ sin x when x ≥ 0.
I don't get it. I know that 1≥sin(x) how should I use the fact you mentioned? I wouldn't noted it if you weren't.
Thanks vela.
The fact that x ≥ sin x for x ≥ 0 is one of those things you pick up along the way, typically when you do a problem like this one.
You're trying to solve for x, right? And the difficulty is that you can't solve an equation of the form xn sin x = c. So you use the usual approach. Instead of solving the equation exactly, you look for an upper bound that you can solve that gives you a good estimate. In this case, you know that x6 sin x ≤ x7.
Thanks man!
One doubt. I was thinking that as the sine is always less than one I could use x⁶ as an upper bound too. Right?
Telemachus said:
Thanks man!
What does this say - x⁶ ?
Telemachus said:
Thanks man!
Yes, you can. So what is the difference between the two choices? Why would you choose one over the other?
sin(x) = 1 for x = pi/2 + 2k*pi, k an integer.
What is x⁶? I can't read the exponent.
Telemachus's idea is to replace sin x by 1, so he'd end up with the inequality x^6 ≤ 0.36.
It's weird. His exponent is in a smaller font than mine.
Sorry, I was studying :P
x⁶ is x^6
I think I would choose x^6 cause its a better approximation than x^7, so I got |x<\sqrt[6]{\frac{9}{25}}
Edit: Ok, I've seen that I was wrong, and that x^7 is a better approximation. But now I have more doubts, damn. For this: x ≥ sin x, or even using x^6 ≥ x^6 sin x, couldn't it happen that using that approximation I would get outside the boundary I was looking for? In this case I've noted that it works, but in general I would like to know what could happens. I mean, while using the substitution it could happens that the new value could be bigger than the error I was looking for, right? cause, I know that x^7\geq{x^6 sin x} and so x^8\geq{x^6 sin x} it is, and even for any n>6 x^n\geq{x^6} right?
Mmm ok, I am wrong for values of x, such that x\leq{1}. I've tried with x^8 and it seems to work too, and its a better approximation for the boundary I am looking for.
http://www.wolframalpha.com/input/?i=x^6+sin(x)+=+9/25
From here I get x ~~ 0.8807530939284029...
And http://www.wolframalpha.com/input/?i=(9/25)^(1/8)
0.88011173679339339727
Nope. As long as your steps are reversible, which they usually are when you're doing these algebraic manipulations, you can start with the condition you found for x and deduce that the error will be within the given bound.
Thanks vela, this is really helpful and very useful.
