How Do You Find the Maclaurin Polynomials for cos(πx)?
Mosaness
1. Find the Maclaurin polynomials of order n = 0, 1, 2, 3, and 4, and then find the nth MacLaurin polynomials for the function in sigma notation.
cos(∏x)
2. Here is what I did:
p0x = cos (0∏) = 1
p1x = cos(0∏) - ∏sin(0∏)x = 1
p2x = cos(0∏) - ∏sin(0∏)x -\frac{∏<sup>2</sup>(cos∏x)(x<sup>2</sup>)}{2!}(
and so on...
And the pattern that forms are that the odd values for k are 0.
So p0x = p1x
and p2x = p3x
etc etc.
fk(x) = (∏)kcos(∏x)'
and fk(0) = (∏)k(-1)k
As for the sigma notation:
Here is what I obtained:
Ʃnk = 0(\frac{(∏<sup>2k</sup>(-1)<sup>k</sup>}{k!}(x)2k
According to the solution manual however, there is a n/2 on top of the sigma notation instead of a n.
I don't understand .
cos(∏x)
p0x = cos (0∏) = 1
and so on...
So p0x = p1x
and p2x = p3x
etc etc.
No. That isn't right if k is odd.
##\sum_{k=0}^n\frac{(-1)^k\pi^{2k}x^{2k}}{k!}##
[Fixed your latex. Don't mix other symbols with tex]
I think the only thing wrong with your final answer is you should have a ##(2k)!## in the denominator. Then note that your general sum gives only the even powers, which are the only non-zero terms. Your book's answer probably has something to do with indexing it differently. Hard to say without seeing it.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
