Did Maggiore Make an Indexing Error in QFT Textbook?
  • Thread starter Thread starter MathematicalPhysicist
    Error Qft Textbook
The discussion centers on equations 2.6 and 2.7 from a textbook, specifically addressing the logarithmic transformation of a product of exponentials involving group generators. Equation 2.6 presents the product of two exponentials, while equation 2.7 takes the logarithm of this product. A point of confusion arises regarding the use of indices, particularly the transition from 'a' to 'b' in the term involving the product of generators. It is clarified that the change in indices is a result of the summation convention, which helps maintain clarity in the summation process. The use of a dummy index, such as 'b', is necessary to accurately track the terms being summed, ensuring the mathematical integrity of the equations. This explanation resolves the initial confusion regarding the notation and its implications in the context of the equations.
In page 15 of the first edition of this textbook, in equations 2.6 and 2.7, he writes:
(2.6)e^{i\alpha_a T^a_R} e^{i\beta_a T^a_R}=e^{i\delta_a T^a_R}
where T^a_R is the generator of the group represented by R.
Now in equation (2.7) he take the logarithm:
(2.7)i\delta_a T^a_R=log{[1+i\alpha_aT^a_R+0.5(i\alpha_aT^a_R)^2][1+i\beta_a T^a_R+0.5(i\beta_a T^a_R)^2]}=log[1+i(\alpha_a+\beta_a)T^a_R-0.5(\alpha_a T^a_R)^2-0.5(\beta_a T^a_R)^2-\alpha_a \beta_b T^a_R T^b_R]
and I don't understand from where did he get the term with the b's, I guess it should a's instead of b's, but then again he writes that he uses the taylor expansion of log(1+x) upto second order to get to equation (2.8)\alpha_a \beta_b [T^a_R,T^b_R]=i\gamma_c(\alpha,\beta)T^c_R, I don't understnad why did he change indexes in equation 2.7, can anyone enlighten me with this?
Thanks.
I don't understand why did he change indexes in equation 2.7,
Your latex's not quite right...
Magiorre's eq(2.7) is
<br /> i\delta_a T^a_R ~=~ \log\big\{[1+i\alpha_aT^a_R+0.5(i\alpha_aT^a_R)^2][1+i\beta_a T^a_R+0.5(i\beta_a T^a_R)^2]\big\}<br /> ~=~ \log[1+i(\alpha_a+\beta_a)T^a_R-0.5(\alpha_a T^a_R)^2-0.5(\beta_a T^a_R)^2-\alpha_a \beta_b T^a_R T^b_R]<br />
which involves abuses of the summation convention. (Actually, even (2.6) should use another
dummy index like b in the second exponential.)
Basically, he uses the b dummy index so that you can correctly keep track of what's
being summed with what...
OK, thanks.
That clears this matter.
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
