Magnet falling though copper pipe
59 replies · 8K views
Orthoceras
I do not fully understand why a falling neodymium magnet is decelerated in a vertical copper pipe. It is usually explained by Lenz's law, two induced currents generate an upward force that counteracts the force of gravity. (link) However, I assume this upward force has to be generated by the free electrons participating in the current, and I would think these electrons do not have a good foothold in the copper. Therefore, it seems more likely that the free electrons would fall downwards through the copper, together with the heavy magnet, instead of decelerating it.
Suppose the copper pipe was replaced by an infinitely long conductor having zero resistance, would that affect the terminal speed of the magnet?
Is there a formula for the terminal speed of the falling magnet in a copper pipe?
The currents produced in the copper pipe (described by Lenz's Law) circulate around the pipe. The electrons do not "fall down" the pipe.
If the copper somehow had no resistance, it could levitate the magnet. Yes one can derive a formula. What do you think the salient variables are (that will be in the formula)?
According to Newton's third law, the electrons participating in the eddy current are inevitably pushed down. If the copper pipe has zero resistance, and is infinitely long, I would expect the electrons to fall down, in a frictionless medium.
If vertical motion of the electrons somehow would be prohibited, for example by replacing the vertical pipe by a stack of copper rings separated by gaps I would expect a terminal velocity to be proportional to the resistivity of copper, ρ. (Something like v ∝ ρBmg). But in the copper tube electrons are free to move vertically.
  • Skeptical
At first, I thought this sentence sounded a bit naive. But once I got through the whole post and thought a bit more, I felt the question is actually not quite trivial.
If we mount the tube in some sort of force balance, then obviously some downward force will be registered as the magnet makes its way down. If the tube has some freedom to move, it will be dragged downwards. So we do need to ask what (upward) force acts on the electrons, such that they in turn can exert an upward force on the magnet.
I think it's just that the electrons do really begin to drift downwards a tiny distance, but then the new charge configuration immediately produces an electric potential that opposes any further drift. There may even be some clever way to measure the potential difference. Perhaps it may be valid to think of it as vaguely analogous to the Hall effect.
Edit: If we replace the tube with an elongated torus (in effect a double walled tube with the inner and outer walls shorted at the top and bottom), would the magnet drop faster, since the electrons are no longer impeded by a voltage buildup?
Edit^2 : If I remember correctly, the drift velocity of the electrons would be of the order of the speed of the magnet, considering the slowed-down motion of the latter. This suggests to me that the upward force on the electrons could just come from collisions with impurities, lattice defects etc --- aka plain old fashioned ohmic resistance. So in a nutshell, the magnet wants to drag the electrons downwards, and it does so -- only the electrons are heavily impeded by collisions/resistance which limits the drift rate, which in turn provides the upward force that we are looking for.
The electrons are "held up" by electrostatic forces whether the magnet is present or not. If I put a piece of lead (same mass as Nd magnet) on the pipe it will compress slightly and the new electrostatic equilibrium will support the weight. Much th same thing with magnet but there are induced currents as well.
This is clear enough as far as the bound electrons are concerned. But do the conduction / free / delocalized electrons also contribute to the rigidity of the metal? And do they experience the kind of forces you refer to?
Every electron interacts with every other charged particle in that chunk of metal (or nonmetal for that matter). If I leave a piece of pipe standing on the table do you think the "free" elctrons will puddle in the bottom of thepipe?
And the term "free" electrons needs to be understood in a very particular way. They are free and mobile because they are bound to a highly periodic scaffold which is the crystal lattice. Their wavelike nature affords them a freedom they would not otherwise possess.
I think the current must be tilted down slightly due to the motion of the magnet. The magnet actually makes a lot of noise whilst descending, and I wondered if it actually rotates on its way down due to the current following a helical path?
Another way to qualitatively understand the physics is as follows: A moving magnet also implies an electric field. The electric field sets the conduction electrons in the copper in motion leading to the eddy currents. Due to energy conservation this counteracts the free fall of the magnet through the force by the induced magnetic field of these currents.
Computing terminal velocity is very difficult but if the pipe had zero resistance then the magnet would be indefinitely suspended in the pipe!
I am primarily interested in applying Newton's third law here. Suppose we connect both ends of the pipe by a copper wire having zero resistance. This eliminates the electrostatic force that previously kept the electrons suspended at a fixed height. In that case an indefinitely suspended magnet would be a violation of Newton's third law.
  • Skeptical
So then the magnet that's stuck to my refrigerator door is violating the 3rd law because it doesn't fall off?
No it will not. The metal also contains the exact same number of positive charges. What are you trying to get at ??
Ok, then I misunderstood why you introduced the electrostatic force in this discussion.
My point remains that the Lorentz force is pushing the electrons that are participating in the eddy current down, and there is no upward force exerted on them (if the resistance is zero, and both ends of the pipe are connected). So I am not sure that the magnet is indefinitely suspended if the resistance is zero.
  • Skeptical
Or better still, (from my post above):
Swamp Thing said:
If we replace the tube with an elongated torus (in effect a double walled tube with the inner and outer walls shorted at the top and bottom), would the magnet drop faster?
If we don't neglect resistance, then the electrons' downward movement would be limited by the ohmic resistance (ultimately down to interaction with defects/impurities).
If we assume zero resistance, it's conceivable that the magnet would drag the eddying electrons down the inner wall, and current would then flow up the outer wall -- hence allowing the magnet to fall freely.
However, this closed loop will create a magnetic field in the volume between the inner and outer walls -- which could again, via Lenz's law, set up an impeding force.
  • Skeptical
I will not try to point out all of the wrong physics being described in the last few posts.
If the copper pipe we replaced by an aligned stack of copper hoops insulated one from another, the physics would change almost not at all. The axial currents do not matter. The double walls essentially would not matter. The important induced currents are circumferential.
Now please answer my question
My assumption in this description is that the cylindrical magnet has a pole at each flat end and is a loose slip fit in the cylindrical pipe ..
The physics could well be totally wrong, but the question that we're trying to answer is, I think, a valid one:
  • The interaction between the falling magnet and the eddying electrons is such that it tends to drag them down (a la Newton's action-reaction)
  • Something must keep them from drifting down.
  • What is that something?
Is there a fallacy or incorrect assumption in the first bullet point, the second one, or in both?
  • Skeptical
hutchphd said:
See #5.
If i may, let me try to elaborate what I think you mean -- just to help pin down where I'm going wrong.
So: As soon as the magnet starts to drag the eddying electrons down, a charge imbalance begins to develop. We have a slight buildup of negative charge at the bottom and a corresponding positive charge at the top. This charge configuration produces it's own force on the eddying electrons, which is what holds them up.
Correct so far?
  • Skeptical
Um, the magnet experiences an upward force from its interaction with the electrons, so the same electrons must experience an equal and opposite downwards force ?
If that's not correct, then that's where my misunderstanding arises.
hutchphd said:
OK once the charge is moving circumferentially what magnetic force is on it as the pole face gets near?
Can we think of the circumferentially moving charge as a sheet solenoid, with it's (eg) North pole facing the magnet's North pole?
This is just speculation - so for the moment let's say I don't really know the answer to your question.
But is it not the case that we have to account for an equal and opposite upward force somehow? And have I understood your #5 correctly, which provides that accounting force?
Yes we do need to talk to Sir Isaac. But those conduction electrons are not really free. They are still strongly coupled to all the the rest of the metal and each other and most of the Newton forces go to the metal as a whole (even if they were" bouncing" end to end the net momentum ends up quickly in the entire pipe (i e the clamp holding it) Incidentally the "individual particle" picture of electrons in solids is not always great physics...
The residual B field will be radial and axial giving axial and radial IXB. Notice the effect of the trailing pole will do exactly the reverse.
Mostly a wave of circulating currents will accompany the magnet...not the electrons per se.
More than you want to know
  • Love
No it would not.
1. There are no electrostatic forces involved here. The Lorentz force is electrodynamic, not electrostatic. There are no charges setting up any electric fields. The charges moving in the pipe are emf-induced.
2. You seem to think of gravity having any effect on the charges. It does not, in any practical sense.
hutchphd said:
What force "drags the electrons down"? The induced electric force is circumferential. Do you understand Faraday,s Law?
The Lorentz force on the electrons that participate in both eddy currents is downward, if the magnet is falling downward
It's not the Lorentz force. The Lorentz force is the force on a moving charge by a stationary B field.
In this case we use the Faraday law. That law states that an E field is induced in the metal circumferentially according to ## \oint \bf E \times \bf dl = - d\phi/dt. ## The minus sign is what makes your assumption as to axial force direction wrong.
If the calculus confuses you, use Lenz's law: the current buildup must be such as to counter the change in the incoming B flux. Looking at your bottom current, the B flux is increasing downward and the right-hand rule applied to the current pushes it upwards, opposite to gravity. Your picture is good, though, in every way including current directions.
vanhees71 said:
The Lorentz force is (in SI units)
$$\vec{F}=q (\vec{E}+\vec{v} \times \vec{B}).$$
Ah, then in #27 I meant only the magnetic part of the Lorentz force, $$\vec{F}= q (\vec{v} \times \vec{B})$$, where B is the magnetic field of the magnet. The magnetic part of the Lorentz force is downward, if the magnet is falling downward.
