Engineering How to Calculate Reluctance and Estimate Force in a DC Electromagnetic Actuator
The discussion focuses on calculating the reluctance and estimating the force in a DC electromagnetic actuator using specific parameters such as wire diameter, number of turns, and current. Participants analyze the reluctance of the magnetic circuit for two different air gap widths, providing calculations that yield values of 2.373x10^5 At/Wb for 0.125 mm and 2.412x10^5 At/Wb for 0.135 mm. The force exerted by the actuator at the 0.125 mm air gap is estimated to be -354.6 N. There are suggestions for improving clarity in calculations and addressing potential confusion regarding the magnetic circuit's definition. The thread emphasizes the importance of accuracy and understanding in solving the problem.
TheRedDevil18
Consider the DC electromagnetic actuator shown in Figure 1 which is constructed using Hotrolled
Silicon Steel laminations. All dimensions shown are in millimeters. For this actuator0.5 mm diameter Copper wire is used for the winding, the bobbin has a thickness of 5 mm,
the number of turns is 61 and the current in the coil is 5.25 A. At a particular position of the
plunger, the width of the air gap AG x is 0.125 mm.
Figure 1:
My equivalent circuit diagram:
Questions:(a) Calculate the reluctance of the entire magnetic circuit when the air gap width is
0.125 mm. Neglect fringing in the air gaps but do not neglect the reluctance of
the iron. Work to an accuracy of less or equal to two percent. [2.373x10^5 At/Wb]
(b) Re-calculate the reluctance of the entire magnetic circuit for the condition when
the width of the air gap has been increased to 0.135 mm. Neglect fringing in the
air gaps but do not neglect the reluctance of the iron. Work to an accuracy of
less or equal to two percent. [2.412x10^5 At/Wb]
(c) Estimate the force exerted by the actuator for the condition when the width of
the air gap AGx is 0.125 mm. [-354.6 N]
Hope you guys can read my circuit diagram. It's a bit untidy because I used a mouse to draw it
Rtg refers to "Reluctance of top air gap"
Rcg refers to "Reluctance of centre air gap"
Rbg refers to "Reluctance of bottom air gap"
The rest are the reluctances of the coreF = NI = (61)(5.25) = 320.25 At = Ftotal
Now, because the dimensions are the same for the top and bottom parts of the circuit, hence their reluctances are the same, that is Rgt = Rgb and Rcore(AB) = Rcore(EF). Therefore the flux must divide equally
So the top branch = Total flux/2 = Bottom branch
Therefore Ftotal = Fcore(DC) + Fcg + Fcore(BC) + Ftg + Fcore(AB) + Fcore(AD)
Rcg = Lcg/u*A = (0.125*10^-3)/(4pi*10^-7)(30*10^-3)(35*10^-3)
= 9.47*10^4 At/Wb
Rtg = Ltg/u*A = (0.125*10^-3)/(4pi*10^-7)(15*10^-3)(35*10^-3)
= 1.89*10^5 At/Wb
If you take the ratio of Rtg/Rcg = 2, therefore Rtg = 2*Rcg
Ftg = Flux/2 * Rtg...1)
Fcg = Flux * Rcg....2)
Substituting Rtg = 2*Rcg in equation 1, you get
Ftg = Flux * Rcg, therefore Ftg = Fcg
The next part I'm guessing ill have to estimate the mmf drop across the airgap ?, so after a few tries I estimated a 79.5% drop of the total mmf in the two airgaps
That is 0.795*320.25 = 254.6 At = Fcg+Ftg
But since Ftg = Fcg, therefore Fcg = 127.3 At = Ftg
I now went ahead and calculated B with the formula
Bcg = Fcg*u/Lag = (127.3)(4pi*10^-7)/(0.125*10^-3) = 1.28 T = Btg
Using the BH curve I found H to be 320 At/m
Using the formula F = Hl, I calculated the drops across the core as follows
Fcore(DC) = 320*(50*10^-3) = 16 At
Fcore(BC) = 320*(52.5*10^-3) = 16.8 At
Fcore(AB) = 320*(50*10^-3) = 16 At
Fcore(AD) = 320*(52.5*10^-3) = 16.8 At
Summing up the drops = 254.6 + 16 + 16.8 + 16 + 16.8 = 320.2 At
I therefore get an error of (320.25-320.2/320.25) * 100 = 0.016 %
To get the total reluctance, Flux total = B*(Area of centre limb)
= (1.28)*(30*10^-3)(35*10^-3)
= 1.34*10^-3
Ftotal = Flux total * Total Reluctance
Total Reluctance = Ftotal/Flux Total
= (320.25)/(1.34*10^-3)
= 2.38*10^5 At/Wb
This is my attempt for part a of the question. I need to know if I did it correctly so that I can proceed to the next part. Thanks for any help :)
Likes katlego
You're not getting responses for one or more of the following reasons:\1. what bobbin?
2. we're supposed to know permeability of "hot rolled silicon steel laminations"?
3. all those numbers give us a headache! I suggest replacing all the numbers on your given diagram by symbols. You can replace them with numbers at the end.
4. what does "Calculate the reluctance of the entire magnetic circuit" mean? There are two "magnetic circuits".
You seem to have the right approach, basically, all things considered.
Hint for (c): virtual work!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
