Magnetic field around a finite wire with different diameter
Changing the diameter of a wire does not affect the magnetic field at a fixed point if the current remains constant, as the magnetic field is primarily dependent on the current and the distance from the wire. The discussion highlights confusion regarding measurements taken at very small scales, suggesting that measurement errors could be influencing the observed changes in the magnetic field. The placement of the wire is crucial, as a thicker wire may have parts that are farther from the measurement point, potentially skewing results. The participants emphasize the importance of accurate measurement techniques in such small-scale experiments. Overall, the relationship between wire diameter and magnetic field strength under fixed current conditions is clarified.
Agnelo
In my simulation I have a wire with a fixed current flowing, I observed if I change the diameter of the wire the magnetic field (B) in a fixed point of the space also changes, is it correct?
That does not seem correct, as the magnetic field depends only the current.
Yeah, I am agree, only the length affects the measurement, but in this case the length does not change, only the diameter, I don't understand what's wrong...
I have a wire with a 0.05A current over a measurement point at 0.03mm (border of wire), the length of wire is 5.08mm and the diameter is 0.025mm or 0.05mm...
with everything on such a tiny scale, I wouldn't be surprised if it was just measurement error
1) why such small lengths of wire and measurement distance and current ?
2) how are you measuring the B field strength ?
How did you place the thick wire on the same position where the thin wire was? Oh yes, nearest point 0.03 mm from the fixed point ... so part of the thick wire is too far from the fixed point.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
