Magnetic field lines in a current carrying circular loop
The discussion revolves around the magnetic field lines produced by a current-carrying circular loop. Participants explore whether each point on the loop generates its own magnetic field and how these fields interact, particularly regarding the intersection of field lines and the implications of the Biot-Savart law.
  • Some participants propose that each point on the current-carrying circular loop creates a magnetic field, while others argue that the field lines are imaginary representations of the overall magnetic field generated by the current.
  • A participant questions whether the magnetic fields produced by individual points on the wire intersect, leading to further clarification about the nature of magnetic fields and their representation.
  • The Biot-Savart law is referenced as a means to calculate the magnetic field, with some participants expressing difficulty in understanding its implications.
  • There is a discussion about whether the magnetic fields from different segments of the wire can be considered independent and how they interact, with some suggesting that they repel each other while others emphasize the principle of superposition in vector fields.
  • Participants discuss the visualization of magnetic field lines, noting that they are not physical entities but rather a representation of how compass needles would align in the field.
Participants express multiple competing views regarding the nature of magnetic fields generated by a current-carrying loop. There is no consensus on whether individual points on the wire produce independent magnetic fields or how these fields interact.
Some participants highlight the complexity of calculating magnetic fields from each point on the conductor, suggesting that practical considerations lead to a focus on the overall field rather than individual contributions.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring concepts related to electromagnetism and magnetic fields.
55sparsh
I wanted to ask that do each point of the current-carrying circular loop would create a magnetic field and hence the magnetic field lines? And if yes wouldn't the field lines produced by each point of the loop would intersect each other? I read somewhere that magnetic field lines never intersect, so magnetic field lines in a circular loop is an exception?
Thank You.
No - no exception needed.
The points in the space inside the loop to not in any way act as sources for the field lines. The line are wholly imaginary and are representative only of the magnetic field that is generated by the current. There are finite lines through the loop... sort-of related to the field strength: when you see lots of lines close together you have a strong magnetic field.
But you've seen the diagrams - have you ever seen a diagram where the field lines cross?
For completeness:
The points of the loop, do not source field lines either - the magnetic field curls around the wire and does not pass through it.
Thanks for the reply Simon..
But now i just wanted to ask whether each point on the Wire (through which current is passing) have their own independent magnetic fields? and if yes then the magnetic field lines produced by each point on the wire intersect each other?
Thank You.
Thanx zz..
But sorry man I am just a 10th grade student, and seriously i am unable to understand this biot-savart law properly...any alternate explanations?? i was just asking that if the current is flowing through a circular loop current carrying wire, would there would be a single magnetic field produced by the whole wire or each point (or each line segment as u say in biot-savart law) will produce its own magnetic field (and hence the magnetic field lines)?
Thank You.
There is no sense of taking each point in the loop as a source of the magnetic field lines. You do can calculate the field for a differential line segment i.e a part of the loop using Biot-savart law.
In simple terms, force fields(electric or magnetic) around any conductor are always the field generated by the system of points constituting the conductor. The main reason is because it isn't feasible to calculate current through each point of the loop and thereby magnetic field due to that point when representing total magnetic field around a current carrying conductor.
55sparsh said:
Thanx zz..
Next time, indicate the level that you can understand IN THE VERY BEGINNING. If not, you'll simply annoy people who put in effort to present a response, and it is all for nothing!
Zz.
Thanks shreya
Nd i am very very very sorry zz... i really am
I respect my ur efforts put in the answer...
Its all my fault...
I m sry :cry:
Didnt want 2 annoy u
Nd shreyakmath
i noe dat calculating magnetic field from each point of conductor is not feasible
but is it true dat in practicality, every point of conductor produces an individual magnetic field??
welcome to pf!
hi 55sparsh! welcome to pf! :smile:
55sparsh said:
… if the current is flowing through a circular loop current carrying wire, would there would be a single magnetic field produced by the whole wire or each point (or each line segment as u say in biot-savart law) will produce its own magnetic field (and hence the magnetic field lines)?
yes to both, but …
… it's horribly complicated, and it really wouldn't help to understand the field :redface:
I'll have a bit of a go:
A small bit of a wire that current passes through has it's own B field looping around it - just one loop. The extra lengths of wire give more loops and, since they cannot cross each other, they are forced to line up around the wire loop like you see in the diagrams.
The lines kind-of repel each other.
55sparsh said:
Nd shreyakmath
yes, each point does produce a magnetic field actually, a field is induced at each point due to a current element dl.
But when studying the effects on conductor, the individual fields aren't considered due to the nature of magnetic field to add up.
Thank You tiny-tim, shreyakmath, ZapperZ and simon bridge for those wonderful answers, these really helped me a lot, I couldn't these things on the Net and the books I had.
So Simon Bridge, do the fields just add up or kind-of repel each other??
And shreyakmath, do you mean that because the magnetic fields just add up, the patterns becomes like the one shown in most of the diagrams
The same applies to each bit of a straight wire carrying a current.
The fields add up, the field lines repel each other. Remember that the lines are just a handy visualization with no physical presence. As a result we usually end up calculating the fields then drawing the lines to illustrate them.
So Simon Bridge do you mean that actually the fields would repel, but their magnitude would add up?
No - fields add up by the superposition principle. These are vector fields so you add the vectors not the magnitudes.
When you want to draw the field lines, adjacent lines act is if they repel each other.
The lines are not the field - they are a representation of the field.
You have seen diagrams right?
Yups Simon I have seen those...
I read this somewhere:
at every point of a current-carrying circular loop, the concentric circles representing the magnetic field around it would become larger and larger as we move away from the wire. By the time we reach at the centre of the circular loop, the arcs of these big circles would appear as straight lines. Every point on the wire carrying current would give rise to the magnetic field appearing as straight lines at the center of the loop.
Now if the field lines would repel how would they reach to the centre and appear like straight lines?
And in this diagram I think the magnetic fields are depicted of only 2 points...isn't it??
It is because they repel - if they didn't you wouldn't get the line bunching up like that.
Diagrams usually show a 2D cross-section of the field-lines because, you know, paper is 2D. The situation in your diagram has a lot of rotational symmetry so it is much the same for any similar slice through the loop.
But remember - these lines are not real - they are just representative - so we don't have to get anal about it. If you think of the lines as the way a compass needle will align at the location, then a compass needle anywhere on the central line will point along that line - which is all it means.
So you mean because the lines repel they result in forming a straight line shown in the diagrams?
You are not paying attention - what did I say the lines represent?
You said that field lines is just a representation of magnetic fields...
So if the lines are representations, so do we take it by convention that these lines repel each other??
The field lines are what you get when you put a lot of compass needles in the field.
That's what they represent - how the compass needles line up. post #18.
The reason the center line is straight through is that a compass in the center points straight through.
To see what I mean when I say the field lines "sort of" repel each other, go get the picture of the lines about a single wire, and compare that with the picture of two wires. The symmetric circles from the wire by itself get distorted and there are two possible results depending on the direction of the current.
But when we sketch the lines, we just use a bunch of rules to get them right. The lines that don't join up look as if they are avoiding each other. I think you need to do some exercizes drawing these things.
Hmmm i will Simon...
THANKS FOR YOUR HELP! :smile: :smile: :smile:...
  • · Replies 28 ·
  • · Replies 22 ·
