Magnetic field of a Spin-1/2-Particle
klpskp
Suppose we have a Spin-1/2-Particle with no charge, like a Silver Atom, fixed at the origin. The magnetic dipole moment is \mathbf{\mu}=\gamma\mathbf{S}, where \gamma ist the gyromagnetic ration and \mathbf{S} is the spin angular momentum.
The magnetic moment creates the magnetic field:
\mathbf{B(r)}=\frac{\mu_0}{4\pi}(\frac{3\mathbf{r}(\mathbf{\mu}\cdot\mathbf{r})}{r^5}-\frac{\mathbf{\mu}}{r^3})
Further suppose we have a charged, spin 0 particle, like a Silver-Ion, at the position z\mathbf{\hat{k}} with the velocity v\mathbf{\hat{i}}. Also suppose that the particle is heavy enough to be treated like a classical object, The magnetic field at the position of the second particle in y and z direction is:
B_z=\frac{\mu_0\gamma}{4\pi z^3}(3S_z-S_z)=\frac{\mu_0\gamma}{2\pi z^3}S_z
B_y=-\frac{\mu_0\gamma}{4\pi z^3}S_y
Now the second particle will experience a force in the y-Direction proportional to B_z and a force in the z-Direction proportional to B_y. Now if we let this particle hit a screen we can measure the deflection in y- and in z-direction. From this, we can infer B_y. and B_z and therefore S_y and S_z. But the uncertainty principle does not allow for S_y and S_z to be measured simultaneously. So where is the mistake?
I'm not sure if the approximation to treat the second particle classically is valid, but it is the same approximation commonly used for calculations in the Stern-Gerlach Experiment. If it is not valid, could you please provide a qualitative description how the probability of finding the second particle on a specific spot on the screen depends on the spin of the first particle?
Thank you for your help :)
I guess you mean ##y^3##, not ##z^3##.
What you have is basically is a magnetic field along an axis ##\hat{n}## that is at a certain angle in the y-z plane. After the measurement, you will know ##S_n##, which will correspond to a superposition of state for both ##S_z## and ##S_y##.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
