Magnetic Reductor: Questions & Answers
  • Thread starter Thread starter Cri85
    Magnetic
The discussion revolves around the feasibility of using magnets to create a magnetic reductor, particularly in relation to an induction motor setup. The user inquires about the possibility of achieving constant angular velocity in a two-rotor system, where the first rotor drives the second, and seeks to understand energy losses due to heating and friction. Concerns are raised about the efficiency of such a system, with speculation that achieving an efficiency of 1 is unlikely due to inherent losses. The conversation also touches on the complexities of maintaining synchronization between the rotors and the potential for catastrophic failure if they become misaligned. Overall, the topic explores the theoretical and practical challenges of implementing magnetic reduction technology.
Cri85
It is a question I asked to myself.
I studied the induction motor at school, and I asked to the teacher if it's possible to use magnets for build a reductor with magnets. She said it's possible but the energy lost in heating will be very high. I would like to know if my forces are correct and how to estimate the losses.
http://imageshack.com/a/img537/1866/zqaJ3k.png
The Rotor1 rotates at 3w clockwise from an external device not drawn. The Rotor2 is push by the Rotor1. I guess the radius of the Rotor1 is 1 and the radius of the Rotor2 is 3. I would like to have w for the Rotor2, but I'm not sure if it is possible.
I have some questions:
1) I think it's possible to use it only if I start the device like I drawn, correct ? The magnet is pushing clockwise the Rotor2: the Rotor2 is acccelarating, the Rotor2 gives an energy to an external device (not drawn), magnets push counterclockwise the Rotor2: it is decelerating. The angular velocity of the Rotor2 is not constant but the mean can be at w, no ?
2) Losses are very high, even w is low ? How to estimate them ? In theory is it possible to have an efficiency of 1 with this reductor ?
3) Maybe this device exist, have you a link ?
I drawn forces:
http://imageshack.com/a/img901/3278/NOjZYC.png
My forces are correct ? The Rotor1 gives an energy F*r*3w*t and the Rotor2 can give F*3r*w*t, the efficiency can be at 1 only if magnets don't lost heating.
For me the angular velocity is not constant but like:
http://imageshack.com/a/img540/668/Pd5ALz.png
If the inner rotor is turning steadily at constant angular velocity, I think the outer one will turn steadily at the same angular velocity. I picture an equilibrium where the N on the inner magnet is just a little closer to the outer N on the forward side than to the outer N on the reverse side. Just enough closer so the larger force forward is just enough to overcome whatever air and friction resistances are involved.
I don't think there would be very much energy loss to friction with decent bearings so very little torque and rotational energy would be needed to keep it moving steadily. Anyone who has chased a magnet around with another magnet will have a good feel for this efficiency. Odd, I seem to recall doing this as a child with one magnet on a table top and the other under the table top, yet there wouldn't have been sufficiently strong magnets over 50 years ago. Maybe tabletops were thinner.
Interesting application:
http://www.magnomatics.com/technology/magnetic-gears.aspx
For me the angular velocity of the Rotor2 is lower than the Rotor1 because the Rotor1 gives an energy F*3*w*t (the radius is R1=1 and the angular velocity is 3w), so the Rotor2 must give the same energy, like the radius is R2=3 and the force is the same, w must be lower no ?
I see your point. Like an automatic transmission torque converter. When a lot of output torque is needed, you have to run the engine faster to provide the necessary output power. However, with the magnetic coupling my mind sees catastrophic failure when the inner ring goes out of sync with the outer one. As the Inner N passes the outer N, there is no torque on the outer ring for a moment, then reverse torque for about as long as there will be forward torque.
Too complicated for me, I guess.
Yes like that. Thanks for your help.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
