Is Magnetism Both Energy and Force?
Magnetism encompasses both energy and force, as it can be transformed into electricity and exerts force on currents. The relationship between force and energy is fundamental, with force being the gradient of the potential energy field. This indicates that the presence of force implies the existence of energy. The discussion highlights that magnetism should not be viewed as a false dichotomy; rather, it is a phenomenon that embodies both aspects. Understanding magnetism requires recognizing its dual nature in physics.
torxxx
My question is magnetism energy or force?
On the one hand, it is energy because it can be transformed to say electricity, on the other hand is the force because, say, in the alternator, it transfers the mechanical to the electric energy .
This is where you need to go back to basic mechanics to realize that the existence of force implies the presence of "energy". This is because "force" F is the gradient of potential energy field U. Mathematically, the relationship is
F = -U
So the answer to your question in the title is : YES.
Zz.
Likes Dale
I agree with @ZapperZ. The question is a false dichotomy.
Magnetism is magnetism. Magnetic fields have energy and also magnetic fields exert force on currents.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
