Magnetism: Poles of Irregular Shapes (Tetrahedron)
  • Thread starter Thread starter Lost in Space
    Magnetism
When magnetizing an irregular shape like a tetrahedron, the poles may not be located at the vertices but rather distributed across the faces. A common view is that one pole could be on the bottom face while the other three faces might represent the opposite pole. In contrast, a hexahedron, with its equal mass distribution, could have poles at opposing points. The discussion emphasizes that magnetic field lines must exit and enter the shape without crossing, adhering to the principle of zero divergence over the surface. If a hexahedron is halved to form a tetrahedron, the polar regions may shift from points to faces, altering the pole distribution.
Lost in Space
If an irregular shape such as a tetrahedron is magnetised, where will the poles be?
Just think of the tetrahedron as composted of many tiny little magnets.
(As it really is, btw).
So one pole could be on a point and the other on a face?
I don't think. I see more realistic the "bottom" face one pole and the other three faces another pole.
It's just that a hexahedron would have an equal mass distribution if magnetised so would that mean that the poles would be located on the opposing points or would they still be located on the faces as you suggest?
Any configuration can be all right.
You just have to make sure that if a "magnetic field line" goes in, it comes out somewhere, and two lines can never cross. (That is, the divergence over the surface is zero).
Of course only a few "easy"configuration can be obtained in reality.
So if the poles were located at the points of the hexahedron and then you were to cut it in half to make a tetrahedron, how would this affect the polar regions of each half? Would the polar region previously located at the point move position to three of the faces as its opposite pole would now be on a face?
