Magnitude + direction of block on an incline
To determine the magnitude and direction of the total force exerted on an 800 gm block sliding down a 30° incline with an acceleration of 1.5 m/s² and a coefficient of kinetic friction (uk) of 0.4, one must analyze the forces acting on the block. The gravitational force acting down the incline and the frictional force opposing the motion must be calculated. By applying Newton's second law, the net force can be derived, leading to the total force exerted by the plane. The direction of this force should be measured counterclockwise from the vertical. A systematic approach involving free-body diagrams and equations of motion will clarify the solution.
jspek9
A 800 gm block slides down an inclined plane that makes an angle of 30° with the horizontal. It accelerates at 1.5 m/s2. uk=.4
Find the magnitude and direction of the total force exerted on the block by the plane. For the direction, give the angle as measured counterclockwise from the vertical (in degrees).
Can anyone give me any insight on how to go about this? I'm completely lost.
Draw a picture of the block. Draw and label the various forces. If it is being accelerated then there must be a net force that is the cause.
Write an equation and solve.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
