Magnitude of changing magnetic field
A square loop with a resistance of 4.00 Ω and an area of 600 cm² is subjected to a uniform magnetic field directed out of the page, with a 12-volt battery connected. The problem requires determining the rate of change of the magnetic field, given that there is no net current in the loop. The relevant equations involve calculating the electromotive force (emf) and the magnetic flux. Initially, the solution was misinterpreted, but it was clarified that the question asks for the rate of change rather than the magnitude of the change. Ultimately, the correct understanding led to the realization that the induced current would oppose the loop's current, confirming the solution's validity.
likthem
A square loop consists of a single turn with a resistance of 4.00 Ω. The loop has an area of 600 cm^2, and has a uniform magnetic field passing through it that is directed out of the page. The loop contains a 12-volt battery, connected as shown in the figure below.
At the instant shown in the figure, there is no net current in the loop. At what rate is the magnitude of the magnetic field changing?
Φ=BAcosθ
ε=-NΔΦ/Δt
ε=-NΔΦ/Δt
ε=-NΔBAcosθ/Δt, A is constant so
ε=-NAΔB/Δt
ΔB/Δt=ε/NA, negative sign is removed because only magnitude is asked for.
ΔB/Δt=12V/(1)(0.06m^2)=200T/s
I worked this out and it turned out to be wrong. I put in 12V as the emf as I thought that the total voltage should be the same as there is no net current in the loop, however that is the only part of the problem that I am uncertain about. The answer must be in T/s.
Thank you in advance for the help.
Never mind, I got it. It wasn't asking for what was the magnitude of the change in magnetic field but the rate of change. Since the induced current from the field will be opposite to the that of that in the loop, the answer should be negative. So I did it correctly, just misread what the problem was asking for.
Thank you!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
