Magnitude of force acting on an object
  • Thread starter Thread starter hunter457
    Force Magnitude
A 1.84 kg mass accelerates at 10.66 m/s² at an angle of 28.8 degrees north of east, prompting a calculation of the eastward force acting on it. The relevant equations include F=ma and its components in both x and y directions. The initial attempts to solve the problem involved setting up equations for forces but led to confusion with multiple unknowns. Ultimately, the solution simplifies to calculating the total force using F = m*a, resulting in a force of 19.6 N. The eastward component is then found to be 17.2 N after resolving the vector components.
hunter457
A 1.84kg mass is observed to accelerate at 10.66m/s^2 in a direction 28.8 degrees north of east. There is a force directed north acting on the object and a force directed east acting on the object. What is the magnitude of the force acting east on the object?
F=ma, Fx=ma, Fy=ma
*FA=force directed north, FB=force directed east, FN=normal force
Fx=ma
-mgsinθ+FAcosα+FBsinβ=ma
-(1.84)(9.8)(sin28.8)+FA(cos61.2)+FB(sin61.2)=(1.84)(10.66)
-8.68698+0.48175FA+0.8763FB=19.6144
0.48175FA+0.8763FB=28.30138
FA=(28.30138-0.8763FB)/0.48175
Fy=ma
FN+FAsinα-FBcosβ-mgcosθ=ma
FN+FAsin61.2-FBcos61.2-(1.84)(9.8)(cos28.8)=(1.84)(10.66)
FN+0.8763FA-0.48175FB-15.8=19.6144
FN+0.8763FA-0.48175FB=35.416
FA=(35.416-FN+0.48175FB)/0.8763
If I put the two equations together to cancel out FA, I still have two unknowns. I don't know what I'm doing wrong. Maybe my FBD was wrong?
Does this problem explicitly say gravity is even involved? This sounds like a simple vector problem.
You're right. I didn't need to use forces to solve this:
F = m*a
= 1.84*10.66
= 19.6 N
If I draw a line from the origin 28.8deg north of east and derive the components, then Fx=the force eastward:
Fx = 19.6 *cos(28.8) = 17.2 N
Looks good :smile:
p.s. Welcome to Physics Forums.
Thank you. I know that I'll be using this forum a lot more :approve:
