Magnitude of static friction force
The problem involves a 500 kg ox accelerating while being held back by a 120 kg plow, with a focus on determining the magnitude of the static friction force exerted by the soil on the ox's hooves. The coefficient of static friction is given as 0.73.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Newton's second law and the relationship between forces acting on the ox and the plow. Questions arise about the necessity of calculating the force exerted by the plow on the ox and how to approach the problem using the combined mass of the ox and plow system.
The discussion is progressing with participants exploring different methods to calculate the static friction force. Some guidance has been provided regarding the application of Newton's second law to the entire system, which may simplify the problem. There is an acknowledgment of the net horizontal force and its relation to the static friction force.
Participants note the importance of correctly identifying forces and the potential confusion regarding internal forces within the ox-plow system. There is also a mention of ensuring proper units in calculations.
pinkpistachios
A 500 kg ox runs and speeds up by 3 m/s2, but is held back by a 120 kg plow that is attached to its back. Assuming the coefficient of static friction between the horse's hooves and the soil is 0.73, what is the magnitude of the static friction force the soil exerts on the horse's hooves (not maximum static friction) which explains the horse's acceleration?
Fsfr ≤ μFN
FN=mg
FN = 500(9.8) = 4900 N
Fsfr ≤ 0.73(4900)
max static friction = 3600 N
^I got up until here. I'm confused about finding the magnitude of the static friction force...do I have to find the force the plow exerts on the horse and subtract that from 3600 N? If so, how would I find that force?
You could find the force between the ox and plow, but it is not necessary to solve this problem.
You have a typo...the acceleration is 3 m/s^2.
You are missing a very important relevant equation. Which one?
I have acceleration and mass, so would I use Newton's second law a = ∑F/m?
3 = (- Fplow on ox + Fsfr )/500
1500 = (- Fplow on ox + Fsfr)
1500N would be the net horizontal force right? Would that be the magnitude of Fsfr ?
No.
You have calculated the net horizontal force acting on the ox correctly, but the net horizontal force acting on the ox includes the sum of both the static friction force and the force between the ox and plow. So you would have to calculate the force between the ox and plow to find the friction force. But instead, apply Newtons law to the entire ox-plow system. Then you don't need that force between ox and plow because it is internal to the system.
If I combine the masses so it's one system and then apply N2L:
3 = F / 620
so 1860 = Fsfr ?
3 = F / 620
so 1860 = Fsfr ?
Yes. But don't forget units. The static friction force is 1860 N. (If you wish, for extra credit, you might want to calculate the force between that ox and plow).
I got it, thanks :)
