Mainly centripetal forces, please check (esp #4)
  • Thread starter Thread starter missashley
    Centripetal Forces
The discussion revolves around calculating various aspects of centripetal force related to a Ferris wheel ride. The linear speed of the Ferris wheel is determined to be approximately 2.199 m/s, while the centripetal force exerted on Sasha's 50 kg body is calculated to be around 34.544 N. To achieve a weightless sensation at the top, the wheel must rotate at a speed of 8.366 m/s. At this speed, Sasha's apparent weight at the bottom of the ride is found to be 465.465 N after accounting for the forces acting on her. The calculations emphasize the relationship between gravitational force and centripetal force in determining apparent weight.
missashley
Sasha's favorite ride at the fair is the Ferris wheel that has a radius of 7.0m.
1. If the ride takes 20.0s to make one full revolution, what is the linear speed of the wheel?
2. What centripetal force will the ride exert on Sasha's 50.0kg body?
3. In order for Sasha to feel weightless at the top of the ride at what linear speed must the Ferris wheel turn?
4. At this speed, how much will she appear to weigh at the bottom of the Ferris wheel?
use 10 m/s^2 for gravity
T = 1/f
f = 1/T
speed = (2)(pi)(r)/period
centripetal acceleration = (linear speed)^2 / radius
centripetal force = mass * centripetal acceleration ------- mv^2 / r
angular momentum = mvr
1. v= 2pir/t
v = (2)(pi)(7)/(20) = 2.199 m/s
2. centripetal force = mv^2 / r
Fc = (50)(2.199)^2 / 7 = 34.544 N
3. centripetal force i think must equal the same as Sasha's weight
(50)(v^2) / 7 = (50)(10)
50v^2 / 7 = 500
50v^2 = 3500
v^2 = 70
v = 8.366 m/s
4. at 8.366 m/s, she will weigh 418.33 N because
(8.366)(50) = 418.33
i didnt check the math but 1,2,3 look good.
number 4 however is incorrect, what you've calculated is Sasha's linear momentum.
Sasha's apparent weight will be equal to the normal force exerted on her at the bottom fo the ride.
For part 4. Consider the at the bottom of the ferris wheel and then consider the direction of the weight and the centripetal force.
so does that mean i have to find her normal weight then times it by the centripetal force?
No. Her weight acts downwards.The centripetal force acts upwards. The resultant of the two forces is her apparent weight
Her weight downward is 500 N and her centripetal force is 34.544N so 500 - 34.544 = 465.465 N. is that the answer?
Fnet = mv^2/r, where mv^2/r is the centripital force.
There are two forces acting on Sasha, gravity and a normal force in opposing directions, so taking the radial direction as positive.
Fn - Fg = mv^2/r
Sasha's apparent weight will equal the normal force, so
Fn = mv^2/r + Fg
