Making a fomula to calculate the max power (electricity)
The discussion focuses on deriving a mathematical formula for maximum power in electrical circuits using existing equations. The user references key formulas, including U = R*I and Up = -ri*I + U0, and attempts to express power as P = I·(-ri·I + U0). There is a request for additional context regarding the specific circuit involved, suggesting that a circuit diagram would aid in understanding the problem better. The conversation emphasizes the need for clarity in circuit analysis to effectively calculate maximum power.
Tqooa Ez
Show how you can make a mathematic formula for maximum power, by using the other formulas.
I think, that U is maybe called V in English.
U= R*I
Up = -ri *I+U0
[/B]
P=I·(-ri·I+U0)P= -ri·I2+U0 I
Hi Tqooa Ez,
Welcome to Physics Forums!
U= R*I
Up = -ri *I+U0
[/B]
Can you give some more context to the problem? Is there a particular circuit involved? (I'm assuming that this is a circuit analysis problem given the names of the variables that you've mentioned). A circuit diagram would be welcomed.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
