Can you make your own plastic with household items?
  • Thread starter Thread starter Halzman
    Plastic
The discussion focuses on creating plastic using milk and vinegar, specifically through the precipitation of casein, a milk protein. The process is straightforward and involves using an acid to curdle the milk, with vinegar being a common choice, although other acids can also be used. Variations in milk type, such as whole versus skim, can affect the hardness of the resulting plastic. For coloring, non-toxic crayons may be a viable option, as they contain stearic acid. The plastic produced is malleable and can be shaped into various forms, such as pendants, which can be further decorated with metallic gel pens. Additionally, a classic method using Borax and Elmer's glue is mentioned, which allows for easy coloring with food dye and can produce different consistencies of a plastic-like substance. Overall, the discussion highlights the versatility and experimentation potential in homemade plastic creation.
Halzman
I was doing some research online, about making plastic, and I came across a tutorial explaining how you can use milk and vinegar to make plastic.
I basically want to be able to make sheets or molds of objects.
I don't really know what questions to ask, I don't really have any background in chemistry (except for wayy back in middle school), but I do have a few things I need to keep in mind.
- what can I add to make the plastic stronger? heat resistant? Clear? Colored?
As i said, i don't have a lot of background information, but you can get technical, i just hope not to technical :)
Thanks.
Chemistry news on Phys.org
Hmm, I've always wanted to try this, but have never gotten around to it. The procedure seems incredibly simple, just precipitate out the casein (milk protein) under acidic conditions and let it dry. Vinegar is not necessarily required- any acid shall work. You might want to try different kinds of milk or maybe even cottage cheese. I would think that whole milk for example would produce a harder plastic compared to that of skim milk because of the higher fat content. As far as coloring the plastic, I'm not too sure. I've used pieces of crayons before to color soaps. The non-toxic ones contain primarily stearic acid. Might work, pure speculation, however. There's tons of variables you can try!
According to this site's instructions on how to make plastic out of the casein in milk,
http://nobel.scas.bcit.ca/resource/plastic/plastic.htm
The plastic comes out maleable and dough-like, you can then shape it like you please and let it dry out over night.
Mold the plastic into any shape you wish. If you wish to make a pendant for a necklace, use a nail to poke a hole in the plastic and let it dry overnight. Once it is sufficiently dried, use metallic gel pens to decorate it in your own design.
Another, clasic, plastic making experiment involves using Borax (Sodium Tetraborate) and Elmers glue. This method is often used to make "slime" or "goo" and is very easy to color (food coloring should work).
From personal experience, I know that depending on the any numbers of ways you mix the two components, you can create plasticy blobs of many different consistensies (hard, soft, watery, ...).
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
