B Manipulating Gravity: Is It Possible?
  • B
  • Thread starter Thread starter wolram
    Gravity
wolram
Dearly Missed
I do not have a paper to quote but this article claims that gravity can be manipulated., is this pie in the sky or is gravity manipulation a possibility?
Creating artificial gravitational fields that humans can manipulate and observe may seem like an idea from science fiction, but one researcher is now looking to turn the concept into a reality.
Read more: http://www.dailymail.co.uk/sciencet...s-using-current-technology.html#ixzz4MDOXczha
Here's the original paper "How current loops and solenoids curve spacetime": https://arxiv.org/abs/1504.00333
I hope the date on which it was submitted (1st April) is not significant. In any case, it seems to be an extraordinarily tiny effect.
wild. I'd love to hear the verdict.
I know this is sci-fi land but what if knowing exactly what to do with those EM fields reduced the amount energy required?
And if perhaps all of human history has been about accumulating the exact information needed - isn't that equivalent to a lot of stored energy?
http://physicsworld.com/cws/article/news/2010/nov/19/information-converted-to-energy
This has been the argument I keep succumbing to for why maybe it's not impossible.
Could be. It would be a direct detection of the gravitational influence of electromagnetic fields. Assuming the calculations are done right, the effect is 14 orders of magnitude weaker than the gravitational wave signal LIGO saw. No, we won't detect it, we don't have the technology to measure effects that tiny.
Calling that "artificial gravity", as done by dailymail, is just nonsense. It is as artificial as the gravity of a rock next to me: I can move it and influence the gravitational field that way. Great. Moving that rock has a larger effect than the one discussed in the preprint.
Likes PeterDonis and berkeman
Hm, the paper doesn't look like an april fool's day joke (at least not at the first glance :-)). To measure the influence on em. fields seems to be out of reach given the tinyness of the effect, but according to GR it should be there.
No. The experiment described in the article you link to does not show that stored information is equivalent to stored energy. It just shows that, by using information, you can manipulate objects using energy from the environment (by taking advantage of random fluctuations), instead of having to supply it yourself. But the information itself isn't energy and isn't equivalent to it.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
