Marion and Thornton Dynamics Problem 7-20
  • Thread starter MARX
    Dynamics
4 replies · 3K views · last reply
MARX
circular hoop is suspended in a horizontal plane by three strings, each of length l, which are attached symmetrically to the hoop and are connected to fixed points lying in a plane above the hoop. At equilibrium, each string is vertical. Show that the frequency of small rotational oscillations about the vertical through the center of the hoop is the same as that for a simple pendulum of length l.
L = T - U
NOT HOMEWORK SELF LEARNING
OK my main problem here is understanding how this is happening if the support is fixed in a plane and length stays l and hoop rotates horizontally then the height of the center of mass should not change
I need help clarifying the picture here what am I missing
From there it's straightforward to set up the Lagrangian
[/B]
zwierz said:
OK thanks again
but I didn't sense from this the the center of mass of the hoop has risen
so U=O?
you are not obliged to understand anything a priori. Just write equations of constraints
My calculation gives the follows. If##\psi## is a small angle of hoop's rotation then the height of the center of mass is ##\frac{r^2}{2l}\psi^2+o(\psi^2)##, here ##r## is hoop's radius
