Mass and two springs in series: How to solve acceleration
The discussion revolves around the dynamics of a mass placed on two springs arranged in series. Participants explore the acceleration of the mass and the interaction between the springs, considering both theoretical and practical aspects of the problem.
  • One participant describes a setup with two springs in series, questioning how to determine the acceleration between the springs as a function of time.
  • Another participant suggests identifying the forces acting on the mass and clarifies the meaning of "acceleration between spring 1 and 2."
  • A reference to a Wikipedia article on series and parallel springs is provided, which includes derivations relevant to the discussion.
  • One participant proposes using the Lagrangian approach to derive the equations of motion, but another challenges the interpretation of the spring arrangement.
  • Clarifications are made regarding the positioning of the springs and mass, with one participant emphasizing that the springs are vertical and the mass is on top.
  • There is a suggestion to apply Newton's laws directly, leading to a discussion about the equivalent spring constant for the series system.
  • Participants discuss the relationship between the displacements of the two springs and how to express the forces acting on the mass.
Participants express differing interpretations of the setup and the meaning of acceleration between the springs. There is no consensus on the correct approach to solve the problem, with multiple methods proposed and debated.
Some participants note the lack of a clear diagram to illustrate the setup, which may contribute to misunderstandings. The discussion includes various assumptions about the spring constants and the forces involved, which are not fully resolved.
Paavo Palikka
Hello!
I have rather simple problem, but I can't find somehow answer for it: There are two springs in series, let's say spring 1 and spring 2. Springs are attached and spring 2 is attached to ground. In the beginning springs are not stretched. Let's say springs have spring constants k1 and k2.
When mass is inserted on top of spring 1, springs start to vibrate. What is an acceleration between spring 1 and 2 as a function of time?
Please believe me, this is not a homework but an engineering problem. My skills on basic mechanics are quite rusty :)
I would appreciate if you could show me not only answer but how to solve this, so next time I can solve it myself. Thanks!
-Paavo Palikka
Have you tried to identify the forces acting on the mass? And what do you mean by acceleration between spring 1 and 2?
Well, let's get the Lagrangian for this setup. Let ##x## be the position of the mass and assume that ##x=0## is the equilibrium position. Let ##L_1## and ##L_2## be the springs' length in the equilibrium position. Then we have
$$V=\frac{1}{2} [k_1 (L_1-x)^2+k_2(L_2+x)^2].$$
Then
$$L=T-V=\frac{m}{2} \dot{x}^2 -\frac{1}{2} [k_1 (L_1-x)^2+k_2(L_2+x)^2].$$
The equation of motion is given by the Euler-Lagrange equation
$$\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{x}}=m \ddot{x}=\frac{\partial L}{\partial x}=-k_1(x-L_1)-k_2(x+L_2)=-(k_1+k_2) x -(k_2 L_2-k_1 L_1).$$
Since by assumption for ##x=0## the force must vanish, we have ##k_1 L_1=k_2 L_2##, and thus
$$m \ddot{x}=-(k_1+k_2) x.$$
As you see, your setup does not reflect two springs in series but in parallel.
You would have springs in series, if you'd not put the mass between the springs but connecting the strings and fixing the mass on one end of the combined spring and the other end at the ceiling.
vanhees71 said:
You would have springs in series, if you'd not put the mass between the springs ...
How did you infer that the mass is inbetween the springs?Ok the post isn't 100% accurate since it doesn't provide a figure or an attached image of some sort but still from what I can infer the springs are in vertical position in series with spring 1 on top and spring 2 on bottom and mass is on top of the spring system.
Hi again!
my question might be quite unreadable, apologies for that. Unfortunately I can't find any good picture from internet, but maybe picture below is suffisient enough.
One should turn it 90 degrees so that ground is down and springs are vertical. g is acting on mass then vertically.
Acceleration between strings means acceleration between these two strings on picture. Surely it is smaller than acceleration of mass, but how much smaller it is?
I would guess that answer could be given as a function of time t, spring constants k1 and k2 and gravitation g.
You mean acceleration of the point between the two springs?
Acceleration between springs does not make much sense. Should be acceleration of some object or even geometric point, if you wish.
Okay, instead of going into Lagrangian let's apply Newton's laws directly but keep in mind that they are equivalent. For a series spring system the equivalent spring constant is k1k2/(k1+k2). You can derive this using the fact that the force on the two springs are equal. If you have difficulty deriving this you can check the wikipedia page posted above. So now we converted the two spring system to one spring.
Now the forces one the mass is clearly a gravitational force and spring force. Let's call the distance of the mass from intial point x. Using Newton's second law mg-k1k2x/(k1+k2)=ma. Since a is the second derivative of x you have a differential equation. After solving this equation for x, you can obtain a by differentiating it twice.
One extra note, you can find the x without finding equivalent k, but this time you need to define x1 and x2 for two springs and find the relationship between x1 and x2(using equal force approach) then the distance of the mass from initial point will be x1+x2. After that you need to write the new equation for the mass since the opposite force will be due to x1 but the acceleration will be second derivative of x1+x2. However you will get the same equation. Hope it helps.
Paavo Palikka said:
Hi again!
Then the two springs are in series, and it's simpler to argue with forces. On both springs the same force are acting. Let again ##x## be the displacement of the mass from it's equilibrium position (then you don't need to consider the gravitational force anymore, because it's for ##x=0## exactly compensated by the springs). If ##x_j## is the change of length on spring ##j## (##j \in \{1,2 \}##) then you have
$$x=x_1+x_2$$
and since the forces are the same
$$k_1 x_1=k_2 x_2.$$
The springs together have a constant ##k##, and then you have
$$F=k x = k (x_1+x_2)= k (x_1+k_1 x_1/k_2)=k (1+k_1/k_2) x_1=k \frac{k_1+k_2}{k_2} x_1=k_1 x_1 \; \Rightarrow \; k= \frac{k_1 k_2}{k_1+k_2}.$$
  • · Replies 17 ·
  • · Replies 76 ·
