qraal
- 787
- 3
Particle beams to push starships have been proposed by different researchers and I've been contemplating using a particle beam to push a Magnetic-Sail. So in pondering the particle-beam pushed sails I realized there hadn't been an analysis of the efficiency of mass-beams: just how efficiently is the energy of the beam transferred to the sail?
I went with the classic approximation first. Initially I considered an inelastic collision in which almost all the relative momentum between beam and sail is transferred from beam to sail. If you imagine the beam particles after impact washing around the sail with just enough energy to get out of the way of the incoming beam, then that's what I considered. Here's the interesting thing I found - the lowest beam energy is achieved when its relative velocity is twice the sail's velocity and thus the beam speed is 3 times the sail's speed in the rest frame.
One point I had to consider was the need to account for the mass-flow of the beam itself, which should change with the relative speed of the beam to the sail. Imagine the mass-beam is composed of a series of pulses which occur with a frequency, fo, in the rest frame. In the sail's reference frame that pulse frequency must be lower in a fashion physically analogous to the red-shift for light. I parameterised it as dm.fo.(Vr/V), where dm is the mass in each pulse, fo the rest frame frequency, Vr the relative velocity and V the velocity of the beam.
After finding the minimum beam-energy for a given thrust was at a beam velocity of 3 times the sail velocity, it meant the energy transfer efficiency was ~8/27 - just 29.63% - for inelastic momentum transfer.
What about elastic energy transfer? Firstly I am not altogether sure that's realistically possible, but I entertained the idea. Turns out the efficiency is 16/27 - just 59.26%, twice the first case.
Now I have to work out the relativistic version, though I am not altogether sure how to go about it. Any thoughts?
