Mass conservation in fluid mechanics
The discussion focuses on the concept of mass conservation in fluid mechanics, particularly in a pipe with constant cross-sectional area. The user seeks clarification on a specific mass conservation equation, which relates the change in mass within a fluid volume to the mass entering and leaving that volume. The derivation involves understanding how mass flow rates at different points in the pipe contribute to the overall mass change. Additionally, the user encounters difficulties with turbulent flow equations, specifically regarding unknown symbols like V_x and λ, and questions why the left side of some equations equals zero. The conversation highlights the complexities of fluid dynamics and the need for clearer explanations of foundational concepts.
r4nd0m
Part of the mechanics course I'm taking this semester are also fluids, but the material our teacher gave us to this topic is very poor (but unfortunately I haven't found a better source). The problem is that there are many "magic formulas", which come just out of nowhere - without any explanation.
I have a problem with the very first chapter and that is the mass conservation in fluids.
So if we have a fluid in a pipe with constant area S,
fluid has density \varrho(x,t) (depending on time and location), and velocity v(x,t) then the mass of the fluid in volume V = S*\Delta x is m = S*\Delta x * \varrho
And now the formula I don't understand occurs:
\frac{\partial (\varrho*S*\Delta x)}{\partial t} = \varrho(x,t)*v(x,t)*S - \varrho(x+ \Delta x,t)*v(x+ \Delta x,t)*S
Could someone plaese explain me how can we come to that equation?
1.Mass conservation implies that the only way in which the mass within the pipe region of length \bigtriangleup{x} and cross-sectional area S is that mass either leaves or enters the region (there is no mass source or sink within the region).
2. The change of mass within the region from time t to t+\bigtriangleup{t} is clearly given by:
\bigtriangleup{m}=(\rho(x,t+\bigtriangleup{t})-\rho(x,t))S\bigtriangleup{x}\approx\frac{\partial\rho}{\partial{t}}S\bigtriangleup{t}\bigtriangleup{x}
3. However, the amount of mass entering the region from the "x"-side during the same time interval is given by:
\rho(x,t)v(x,t)S\bigtriangleup{t}
whereas the amount of mass leaving at the x+\bigtriangleup{x}-side is given by:
\rho(x+\bigtriangleup{x},t)v(x+\bigtriangleup{x},t)S\bigtriangleup{t}
Thus, we have an alternative expression for \bigtriangleup{m}:
\bigtriangleup{m}=\rho(x,t)v(x,t)S\bigtriangleup{t}-\rho(x+\bigtriangleup{x},t)v(x+\bigtriangleup{x},t)S\bigtriangleup{t}\approx{-}\frac{\partial}{\partial{x}}(\rho{v})S\bigtriangleup{x}\bigtriangleup{t}
4. Setting these expressions for the change in mass equal to each other yields finally:
\frac{\partial\rho}{\partial{t}}=-\frac{\partial}{\partial{x}}(\rho{v})
thanks a lot, this was really helpful.
But unfortunately I am stuck again - now with turbulent flow:
\frac {\partial \rho v_{x}}{\partial t} + \frac {\partial \rho v_{x}^2}{\partial x} = -\frac {\partial p}{\partial x} + \rho g_{x} - \frac {\lambda \rho V_{x}^2}{2D}
there are some symbols that are unknown to me - D is probably hydraulic diameter, but I don't know what V_{x} and \lambda stand for. And another thing - further in the text when solving some problems the left side of the equation is 0 - why?
Any ideas?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
