Exploring Mass Dilation: The Effects of Acceleration on Relativistic Mass
In summary, protons are accelerated from rest to a velocity where their relativistic mass has increased to 400,000 times their rest mass in a series of steps, starting with an energy of 50 MeV in the PS Booster and ending at a nominal energy of 7 TeV in the LHC. The entire process takes approximately 20 minutes.
  • #36
utesfan100 said:
So, because angular momentum in quantum mechanics comes in discrete steps, angular momentum in GR is not dependent on v?
"Furthermore, experiments show that most subatomic particles have a permanent, built-in angular momentum, which is not due to their motion through space. This spin angular momentum comes in units of h_bar. For example, an electron standing at rest has an angular momentum of h_bar/2."
If you have further issues with the above, I suggest that you look at the Rindler derivation.
  • #37
kev said:
The link you gave talks about spin angular momentum and the Planck constant [itex]\hbar[/itex] which is certainly a constant, but I have a strong hunch that the h used by Rindler is not the Planck constant or the quantum mechanical spin. Could you check that?
Yes, I checked. I suggest that you buy the book.
  • #38
starthaus said:
There is no "force" in the formalism presented by Rindler because there is no such thing as gravitational force in GR. Trying to hack the relativistic mass into the Newton formula is definitely the wrong way to go.
The authors of the papers (Matsas and Jonsson) I quoted are happy to hack the way I did for a local first order aproximation. You are right that there is no such thing as gravitational force for a free falling object in GR, but there is a force when a horizontally moving object has zero vertical velocity and is therefore not free falling.
  • #39
Yes, I saw that. Two wrongs don't make a right. I would always take Rindler over both of the others. I just started looking at the Jonsson paper, it is especially bad, especially when you look at his derivation for equations (1)-(3). As Pauli would have said, "not even wrong".
  • #40
Does GR fail to have momentum? I would think that force could still be defined in terms of dP/dt. Is the momentum along a geodesic constant? I think the Earth's momentum as it follows its geodesic around the Sun demonstrates otherwise.
I will concede that such might not be a tensor, as gravity itself cannot be a tensor due to its intrinsic second order effects.
If the energy in the stress energy tensor includes kinetic energy, gravitation must be velocity independent.
I am not certain that the formula:
F=G/c4 E1E2/r2 might not be better than Newton's law of gravitation. It certainly works better for photons than using rest mass.
  • #41
Kev, in another thread you wrote -
kev said:
Imagine a train on a long straight horizontal monorail that is suspended from springs that directly measure the weight of the train and the rail. When the train is accelerated to the same velocity as the bullet in the OP will the track scales directly measure the train to be 7 time heavier?
I, too, was disappointed that you received no response. I submitted no comment due to my inadequacy.
Please excuse my ignorance and possibly incorrect terminology but in accordance with the principle of equivalence your train, initially at rest, is analogous to an apple on a tree which is being acted upon by a gravitational field. When the stem gives way the apple starts moving (as does your train) and because it is then moving it incurs a relativistic mass increase as a result of which the Earth applies a stronger force of gravity to the apple and the apple's velocity accordingly increases (ad infinitum).
If the apple lands on a set of scales wouldn't that device initially, momentarily, determine a greater mass for the apple than its rest mass (analogous to your track scales determining that the train has become 'heavier')?
  • #42
kev said:
...there is no such thing as gravitational force for a free falling object in GR.
Isn't it more correct to state that a free falling object feels no force acting upon it?
A free falling object accelerates because there is a gravitational field acting upon it.
If an observer is falling in a gravitational field he is presumably entitled to realize that the cliff face is accelerating past him because an (albeit otherwise indeterminable from his point of view) gravitational field is acting upon him.
  • #43
The case for vertical velocity is a little tricky and if I am honest I would admit I not certain of the answer to this. (It would be nice to have a definitive answer to the horizontal case first). It is worth considering that that the inertial resistance of the apple to being accelerated downwards also increases and this might cancel out the apparent increased force of gravity acting on it so that appears to accelerate downwards normally. It is also worth noting that in coordinate terms a particle dropped from infinty towards a Schwarzschild black hole appears to slow down as it gets near the event horizon while locally it appears to be speeding up. Tricky eh! Sorry, I can not be more helpful here.
In relativity he is also entitled to consider himself stationary and "something" is accelerating the cliff upwards.
  • #44
If you can link to Rindler's derivation that would be useful, as I don't have it available.
I am not arguing that subatomic particles do not have spin 1/2 values that contribute to angular momentum. That would be silly, as the splitting of electron rays in a magnetic field shows otherwise.
It is only the intrinsic angular momentum that is quantized and constant. The dynamic angular momentum is very velocity dependent. In most systems (including electrons in the outer shells of the heavier atoms) the dynamic angular momentum of the particles greatly exceeds their intrinsic momentum.
Introducing planks constant into a relativity discussion is futile until a quantum theory of gravity is achieved. At least wait until we can explain the http://www.hindawi.com/journals/aa/2009/931920.html" .
  • #45
It covers several pages, so, I suggest you invest in the book.
  • #46
You obviously don't appreciate the financial constraints of community college support staff.
  • #47
I would tend to agree that Rindler is more authorative, but he is also harder to follow and understand. I managed to find a google preview of the Rindler book http://books.google.co.uk/books?id=...&resnum=3&ved=0CA4Q6AEwAg#v=onepage&q&f=false but unforunately the page with equations you mention is not available.
The preceding pages are visible and I can see that on page 238 he states h is a constant and on page 239 he defines h as angular momentum per unit rest mass. This suggests to me he is not referring to h as quantum mechanical spin angular momentum, but rather just regular angular momentum being used as a sort of affine parameter. In other words he is taking the initial angular momentum at a radial coordinate very far from the gravitational body and using that as a constant parameter which is valid. This means the quantity on the right is mass times a constant. Now I will have to try and figure out what the rest of the equation is saying.
  • #48
This sounds like the angular momentum relative to the center of mass of a rotating object, Iw. In this case I would expect the moment of inertia to increase with the relativistic mass and w to slow down canceling the effect.
The angular momentum of the object about its own axis is constant. Its angular momentum about some distant object remains very velocity dependent.
  • #49
I think Rindler is effectively saying that as the particle descends and its inertial mass increases, it's angular (orbital) velocity decreases (in coordinate terms), such that its angular momentum is a conserved quantity and remains constant.
This fourmilab page http://www.fourmilab.ch/gravitation/orbits/ seems to be using similar equations to Rindler, except they use L with a tilde over it instead of h.
  • #50
The apple does not simply appear to accelerate it does accelerate and because it accelerates then it seems obvious that the increasing force of gravity acting upon it is more than sufficient to overcome the apple's increasing inertial resistance.
As you effectively point out - the particle appears, to a distant observer, to be slowing down as it approaches the event horizon but assuming that he is aware of the fact that as the particle moves closer to the black 'hole' the light that the particle emits reaches him at progressively slower velocities he should be capable of realizing that what appears to be taking place is nothing more than a visual illusion.
He falls off a cliff and at that very instant 'is' of the opinion that not only the cliff but also the entire universe is accelerating in a particular direction!
Presumably being scientifically inclined he might perhaps ask himself what (greater-than-infinite and increasing) force could cause an infinite universe to accelerate.
  • #51
Uhhh... doppler shifting isn't "illusory", it's a real effect, and it's also very real that the observer will NEVER be able to see the 'astronaut' falling past the horizon. In the same way, the issue of the scientist you propose requires that he be aware of initial conditions to make his judgement, otherwise... still relative. The fact that he'll fall to his death doesn't change the nature of relative motion or Relativity.
  • #52
I think I found Starthaus' objection to the long monorail example. Compare the velocity described for the train to the escape velocity of the Earth and consider which way the force must go.
Now, suppose a thin ring is supported by a stand and then spun to a speed where its mass is moving at v=0.6c along the ring. Would the stand feel more weight to support the ring?
  • #53
Sure, if the train is exceeding orbital velocity on a spherical massive body then it will take off, but I would like to consider a very localised version on a very large flat earth, to give us an idea of what happens when considering situations like the one you describe below.
By the orbital argument, a mass moving with orbital velocity parallel to the surface of the Earth experiences zero or negative gravity. Now consider a helicopter with masses on the end poles instead of lifting blades on a gravitational body with no atmosphere. What will happen if the rotor rotates with relativistic tip velocities that exceed the escape velocity of the massive body? Will the helicopter be able to hover or ascend in no atmosphere just using the rotational velocity of its rotor tip weights? I think the answer is no.
Most of the things I have read would say the answer is yes.
  • #54
In this case the rotor provided the force to keep the tips in place, circling above to no effect, other than to keep the helicopter grounded by the increase in mass caused by their rotation.
  • #55
OK, we are in agreement here.
  • #56
My comment had absolutely nothing whatsoever to do with doppler shifting!
If a far distant observer is looking at a beam of light that is heading directly toward a black 'hole' that beam will accelerate! (He cannot, of course, actually see that beam - it is only a hypothetical situation.)
Similarly if he is looking at a beam that is moving directly away from that object the velocity of that beam, relative to him, will be dependent upon the distance of its source from that black star (assuming that the source is external to the event horizon).
Irrelevant. I made no reference to an [object] falling past the horizon.
Frame Dragger said:
In the same way, the issue of the scientist you propose requires that he be aware of initial conditions to make his judgement...
I specifically wrote that the scientist falls off a cliff! He cannot fall off a cliff unless he is initially located on that cliff ergo is presumably aware of the initial conditions - assuming mental competence/awareness of course.
He could, of course, have been rendered unconscious and thrown off the cliff but I prefer to stick with relevance.
  • #57
I found another article http://www2.warwick.ac.uk/fac/sci/physics/teach/module_home/px436/notes/lecture16.pdf that has equations similar to those of Rindler. Starthaus is obviously talking about "effective potential" where the effect of centrifugal potential due to orbital velocity around the massive body is subtracted from the gravitational potential. For a circular orbit the potential gradient is zero. In the case of the weight of a small spinning ring, orbital velocities are not relevent.
  • #58
Yes, this is good but not as good as Rindler. In essence it is an abstract of Rindler's chapter 11, minus the proofs.
Rindler is talking about particle orbits in Schwarzschild space. This describes exactly the motion of particles at LHC, i.e. it answers the OP.
As an aside, the Jonsson paper is pure nonsense, AmJPhys publishes a lot of bad papers when it comes to relativity. The other paper (Matsas?) is not even peer-reviewed.
  • #59
I either stand corrected, or deeply confused. Actually, the latter regardless of the former.
That I understand, but I'm not grasping why this is significant in this situation. I don't mean that sarcastically, I just (clearly) don't get it.
Agreed, but given all of that, how is this a question which touches on Relativity at all? You have your initial and final velocities of the hapless scientist (the final being most upsetting to him), and all other conditions set; you have your IRF of the scientist established.
Well, relevant, but genuinely cruel, :biggrin:
If there is a single source of my confusion here, it would be that what you're ascribing to an illusory effect, seems more to do with gravity as fictitious force, than relative motion. I wouldn't argue that we can establish IRFs, or that at the end of the fall distant observers will agree on the end result (thud), but I don't see what it is you're illustrating.
  • #60
You wrote that you understand that if a far distant observer is looking at a beam that is moving directly away from that object the velocity of that beam, relative to him, will be dependent upon the distance of its source from that black star.
In accordance with that concept - the light emanating from a source that is at a (hypothetically) fixed location relative to a black star will travel toward the distant observer at a slower rate than the light from an object that is located further away from the star.
Similarly, the light emitted by both sources toward the star will accelerate.
Imagine that you are at a vast distance from a light source that emits beams of light to your right hand side and to your left. Obviously (although you cannot actually see those beams) they will both be moving at identical speeds away from the source however if the source starts accelerating in the same direction as one of those beams that beam will be moving away from the source at a slower speed than the other beam (but only whilst the source is accelerating).
In accordance with the principle of equivalence - if a source is at a fixed distance from a black star the beam that is projected toward the star will accelerate whilst the other beam will travel away from the source at a (slower) velocity that is dependent upon the source's distance from the star (however only from your, far distant, point of view not from that of an observer located alongside the source).
If you fail to see how this touches on relativity and mass dilation I cannot clarify the situation.
We do not have our IRF of the scientist!
He is accelerating hence is not in an inertial reference frame!
Frame Dragger said:
If there is a single source of my confusion here, it would be that what you're ascribing to an illusory effect, seems more to do with gravity as fictitious force, than relative motion. I wouldn't argue that we can establish IRFs...but I don't see what it is you're illustrating.
My description of an illusory effect is that it is the fact that the speed of the light traveling toward a distant observer from an object that is falling into a black star slows down as the object enters stronger gravitational tidal areas giving the distant observer the impression that the object's rate of travel toward the star is decreasing but in reality (and the distant observer should be fully aware of this fact) the object is accelerating.
The illusory effect is analogous to when a person sees a mirage; the scene is not actually where it appears to be in the same way that if we see a star that seems to have changed locations as its light bypasses a massive body (e.g. during an eclipse) that star has not physically moved; this is only a visual illusion.
  • #61
As I understand it, light does not "slow down" or accelerate as it approaches black hole (Black Star if you prefer), but that its degrees of freedom become increasingly limited, until all possible paths lead past the Event Horizon.
At no point is light's velocity changing except in regards to the medium it is passing through. A mirage is the result of refraction, and while I'm not contesting the notion of gravitaitonal lensing, it doesn't have a thing to do with why an observer will simply see the scientist grow dimmer, and dimmer, redder, and redder.
You seem to think that light is "sucked" into a black hole, rather than following a geodesic into it. That has nothing to do with a geometrical view of gravity, nor does "accelerating light". I'm sorry cos, but if the light accelerated, there would BE no relativity. Using sceintists falling off cliffs, or black holes isn't materially different from trains. Light's speed in a given medium is CONSTANT, and the gravity of a "black star" simply restricts possible geodesics that would lead to an escape. At no point is "c" changing, at least, until you get past the EH, then who knows.
  • #62
To clarify the situation - I made no suggestion that light slows down as it approaches a black star; it speeds up!
(I prefer the title 'black star' on the basis that there is no 'hole' - that this is nothing more than a fanciful description aimed at impressing the general public).
(Incidentally - to set the record straight - my references are to beams of light that are moving radially toward or away from a black star not tangentially relative to same.)
Light does not slow down as it departs a black star; its velocity is determined by the location of its source in the star's gravitational tidal area i.e. its distance from the star.
In a previous message I wrote -
To which you responded -
That I understand...
I take it that you understood but did not accept it?
Were you able to understand my depiction of your looking at a distant source that emits beams of light to your right hand side and your left hand side then the source accelerates?
Are you of the opinion that the beam that is moving in the same direction as the source will not be moving away from the source at a slower rate than the other beam or are you of the opinion that the principle of equivalence does not apply to this concept?
I sincerely hope that with your comment "light does not 'slow down' or accelerate as it approaches black hole..." you are not resorting to the dubious practice of referring to a determination made by a local observer.
All of my postings apply to events that take place this side of the event horizon so it would be appreciated if you did not refer to this obfuscatory material.
At no point is light's velocity changing...
I reiterate - In a previous message I wrote -
I assume that you understood but did not accept it.
Please do not introduce obfuscatory material. Light approaching or departing a black star may well be passing through a medium that is accelerating toward the star however this should not be taken into account in relation to a hypothetical situation of light moving through a vacuum.
It would be very much appreciated if you did not twist my words!
I said nothing about the observer seeing the scientists image becoming dimmer and redder! My comment was in relation to the claim that a distant observer will see the scientist slowing down as he approaches that object not accelerating!
The fact that the distant observer will see the light emitted by the scientist slowing down as he enters progressively stronger gravitational tidal areas may give him the impression that this is taking place however assuming that the observer is of reasonable intelligence he should be able to realize that whilst the scientist appears to be slowing down this is nothing more than a visual illusion and that the scientist, just like all other forms of matter, is accelerating!
Your deprecatory remark verges on a personal insult and further applications will terminate this discussion. I would be appreciated if you did not try to put words in my mouth or make accusations!
As does all other matter, light falls into a gravitational field. It is not 'sucked' by gravity.
A beam of light that is traveling directly (radially) toward a black star is not following a geodesic (i.e. following the shortest possible line between two points on a sphere or other curved surface).
In his book 'Relativity' http://www.bartleby.com/173/ Einstein wrote (76) -
"...our result shows that, according to the general theory of relativity, the law of the constancy of the velocity of light in vacuuo...cannot claim any unlimited validity. A curvature of rays of light can only take place when the velocity (more correctly - the speed) of light varies with position...[SR's] results hold only so long as we are able to disregard the influences of gravitational fields..."
The speed of a beam of light varies depending on its position (i.e. its location) relative to a gravitational source and in the case of a black star a massive, virtually infinite, source of gravity.
Einstein continues that whilst some people are of the opinion that GR overthrows SR (that in your words 'there would BE no relativity') he points out that SR 'lives on' in GR 'as a limiting case' in other words - when there is no gravitational effect but to the best of scientific knowledge there appears to be no such thing as a totally zero gravitational location.
What does the fact that light's speed in a given medium is constant have to do with a beam of light that is moving toward or away from a black star? At that instant the star may have already absorbed any medium in the vicinity of the beam.
At no point is "c" changing...
"[SR's] results hold only so long as we are able to disregard the influences of gravitational fields." (Albert Einstein)
SR's 'results' include the theory that the speed of light does not change yet according to Einstein we should disregard SR's results when gravity is involved.
  • #63
To local observers, the speed of light is constant (always equal to c). To a distant observer the coordinate speed of light slows down as it travels deeper into the gravitational well. It is necessary to state the location of the observer when making statements about the speed of light in a gravitational field and both you and FD are guilty of not doing this.
How do I arrive at the conclusion that the speed of light slows down as it falls according to the distant observer? First consider a clock that is lowered to radius r in a gravitational well and then at r for a period and then brought back up. The time that elapses on the lowered clock is less than the time that elapses on a clock that remains high up. The time dilation effects during the traveling phase of the lowered clock while being lowered and raised can be eliminated by comparing to the results to a control clock that is lowered and raised without the dwell time t. The results show that gravitational time dilation is real. Clocks really do run slower deep in a gravitational well, relative to a distant clock. An observer deep in the well considers the distant clock to be running faster than his own clock and the distant observer considers the deep clock to be running slower than his own clock. Both observers agree that the deeper clock runs slower. There is no ambiguity of reciprocal clock rate measurements as in SR.
Now if you agree that clocks near a gravitational source really do run slower relative to distant clocks, then if a local observer measures the local speed of light with a slow clock to be the same as the local speed of light as measured by a distant observer using a faster clock, then the speed of light must be different at the different locations in a relative coordinate sense. The only way this can be avoided is by having vertical rulers that get longer by a factor of gamma = 1/(1-2GM/r) to cancel out the effect of slower clocks, but the Schwarzschild metric says exactly the opposite and rulers get shorter by a factor of gamma deeper in the well. In fact the vertical coordinate speed of light measured by the distant observer gets slower by a factor of gamma squared, the deeper you go into the well.
Black star implies a body with a solid surface, while the "surface" of a black hole is an event horizon rather a solid surface and the event horizon encloses a region that is a vacuum except for a point with infinite density at the centre of the region. The conventional view in GR is that a body with greater than the Schwarzschild density does not have a solid surface and so it is not described as a black star.
You are right that light does not slow down as departs a black hole. It speeds up as it rises, from the point of view of a distant observer and is constant from the point of view of the local observers that the light passes on the way up.
There is nothing dubious about FD referring to the measurements made by a local observer. The only dubious practice is not making it clear what observer makes the measurement, when making statements about the speed of light.
  • #64
I have the same problem with "speed-up" as "slow-down".
Whereas "black star" is what.. less fanciful? It's not a star anymore, and "hole" is a decent approximation for an inescapable region of spacetime. To be honest, "Black Star" sounds a hell of a lot more fanciful that "Black Hole" in terms of capturing the public imagination; not that I believe for a second that is the point, but you're entitled to your opinion.
cos said:
(Incidentally - to set the record straight - my references are to beams of light that are moving radially toward or away from a black star not tangentially relative to same.) Light does not slow down as it departs a black star; its velocity is determined by the location of its source in the star's gravitational tidal area i.e. its distance from the star.
Let me pose this to you: Take your light beams and have them at orbital distance from the BH/BS, but now make it the original star. Do you still believe that the velocity of light is determined by its distance from the star?
cos said:
<snip> Were you able to understand my depiction of your looking at a distant source that emits beams of light to your right hand side and your left hand side then the source accelerates? Are you of the opinion that the beam that is moving in the same direction as the source will not be moving away from the source at a slower rate than the other beam or are you of the opinion that the principle of equivalence does not apply to this concept?
I think you need to explain how it applies, and how that squares with GR.
I am saying that outside of an Event Horizon, the speed of light is constant in a given medium, including a vacuum. My understanding of how light "falls" into a gravity well is due to restriction of its degrees of freedom, and possible escape routes, not by altering its speed. That is the ONLY reason I mentioned event horizons at all. I don't believe that clarifying my point is obfuscating anything.
cos said:
Please do not introduce obfuscatory material. Light approaching or departing a black star may well be passing through a medium that is accelerating toward the star however this should not be taken into account in relation to a hypothetical situation of light moving through a vacuum. It would be very much appreciated if you did not twist my words!
See previous, I'm not twisting anything, anymore than I am secretly editing your posts. I was saying clearly (I thought) that light's speed is CONSTANT unless you DO invoke a medium.
cos said:
I said nothing about the observer seeing the scientists image becoming dimmer and redder! My comment was in relation to the claim that a distant observer will see the scientist slowing down as he approaches that object not accelerating![/quoter]
You do realize that every time I respond to you, I'm not trying to reframe the argument, I'm actually trying to make a point as well? Slowing down, gravitational redshifting, slower apparent tick rates on clocks... I'm making the point that it's not an "illusion", but a real effect. If an infalling astronaut (my model this time) manages to escape a Black Hole before passing through the EH, they will experience very REAL effects of differential aging/time dilation, much as they would in the twin paradox or The Planet of The Apes!
... See previous.
Taking something as an insult is not the same as being insulted. I made an observation which reflects how I see this discussion trending. You have been curt to the point of rudeness, and I have not been. There is a difference between being insulted, and being pissed off, and I think right now you're the latter. What did I accuse you of? What words did I put in your mouth? I said, "You seem to think that light is "sucked" into a black hole, rather than following a geodesic into it." I still think that, and nothing you've said makes me think otherwise. I don't mean that as an insult, or an accusation.
Meanwhile you've grown increasingly hostile, so I am going to leave this to others to either correct my errors, yours, or both. You either want a fight, or seem unable to have a civilized discussion ONLINE. You don't have to worry about "terminating the discussion"; you fired it up after a 4+ day break, and I frankly wouldn't have even known you'd commented other than the auto-notify feature. My investment here is 0 + mild interest - your hostility = "Me gone until/unless a mentor/advisor decides to correct me, you, or both." I simply don't care about this enough to deal with someone who takes an observation as an accusation.
If I'm wrong, I can learn on my own or with others, and if you're wrong I no longer care about your possible misconceptions in the slightest. I'm not trying to be insulting, but enough of this nonsense. You've made a discsussion into a contest with only one participant. Bravo.
@Kev: Thanks, and you're right about not making clear who's making the measurement, but I'm arguing that the effect is not "illusory".
  • #65
To local observers the speed of light is only determined to appear to be constant due to the fact that their measuring rods and clocks are distorted by that gravitational field.
It is noted that neither of you responded to my analogy so I will repeat it in the hope that you will answer.
You are looking at a light source that is some distance from you and contained within your reference frame - it is stationary. External to and concentric with the light source is a semi-transparent sphere.
The source simultaneously projects beams of light to your right hand side (A) and to your left (B). Those beams will, according to light speed constancy, reach the sphere at the same instant from your point of view (assuming no influence by any gravitational field) as well as from the point of view of an observer standing alongside the source.
The source starts accelerating to your right but the sphere remains stationary. Beam B will reach the sphere before A ergo beam B is traveling away from its sourcefaster than A.
Now imagine that a source and its associated semi-transparent sphere are (hypothetically) located at a fixed distance from a black star . According to the principle of equivalence this is analogous to the source accelerating in the above depiction.
From your point of view, the beam (B) that is moving toward the star travels a greater distance in one of your seconds than a beam (A) that is moving in the opposite direction! Beam B will arrive at the semi-transparent sphere before A reaches the sphere.
The rates of travel of those beams away from their source, from your point of view, are not identical!
Those beams, relative to you are moving at different speeds.
You now move to the source's location ergo becoming a local observer. You have witnessed one beam moving faster than another beam however your, now, gravitationally distorted measuring rod and clocks indicate otherwise.
Some people may be able to realize that because their measuring devices are distorted due to gravity they are not providing 'true' readings.
An observer is located on a mountain top. He finds that a clock at that location is ticking over at precisely the same rate as his own clock.
He moves to sea level where he finds that a clock at that location is also ticking over at the same rate as his own clock but looking back at the mountain-top clock he notes that it is ticking over at a faster rate than his own clock.
He could either conclude that for some reason the rate of operation of the mountain top clock has increased or (via a Confucian proper application of knowledge) that it is his clock, now located in a stronger gravitational tidal area, that is ticking over at a slower rate than it was when he was atop the mountain.
Some people may be able to realize that his clock is affected (changed, 'distorted') by his location in a gravitational field whilst others insist that the mountain-top clock's rate of operation physically changes.
When you change your location from a far distance and become a local observer you, too, may be able to realize that your rods and clocks have been physically affected (changed, 'distorted') due their present location in an intense gravitational field.
It would be very much appreciated if you did not edit this analogy and if you responded to same!
I have endeavored to make every attempt to state the location of the observer however when I write that a beam of light will accelerate toward a black star I am talking about from every observer's point of view on the basis that a local observer should be able to realize that his rods and clocks are distorted by that intense gravitational field.
You write "..the Schwarzschild metric says exactly the opposite and rulers get shorter by a factor of gamma deeper in the well."
Imagine that a ship is at a fixed distance from a black star. The astronaut, using equipment on the ship, manufactures steel rods of identical lengths one of which (A), fixed to the ship, extends toward the black star whilst the other one (B) extends in the opposite direction. As the result of spaghettification, rod A will be physically longer than B which is compressed in length irrespective of the fact that the stamp on the ends of both rods indicate identical manufacture lengths.
Your 'point with infinite density at the centre of the region' is presumably what is also known as a singularity - a totally hypothetical concept that has never been located. I cannot accept that it has 'infinite density' i.e. that it has a density equivalent to that of the entire universe.
If a massive star collapses to the size of a basketball it obviously has a solid surface; if it collapses to the size of a pea it obviously has a solid surface; if it collapses to the size of an atom it obviously has a solid surface.
When somebody actually trips over a singularity or a point with infinite density and returns to inform us that it has no solid surface I might be persuaded to accept this pronouncement.
Light travels away from such an object at precisely the same speed as its escape velocity. It has no access to any form of energy that would generate an increase in its speed and has no inherent energy that it can expend in order to do so.
The only way that light can speed up as it moves away from a gravitational source is if the source is surrounded by, for example, an atmosphere.
FD did not make it clear, and made no attempt to do so, as to which observer he was referring. I agree with you that this is a dubious practice which is what I suggested he may have been guilty of doing!
  • #66
You seem to be saying that particles in the LHC are effectively orbiting the Earth. You also made it clear earlier that you do not think relativistic mass (or a term that looks like it) plays no part in calculating the gravitational force acting on a particle. There appears to be a fundamental difference in opinion between the memebers of this forum which can be encapsulted in the answer to this this simple question. "Does a spinning brick weigh more than a non spinning brick?" I think most people here would say yes and you seem to be saying that no, the spinning brick will weigh less (or the same?) as a non spinning brick. More extremely, you seem to be saying that if parts of the spinning brick had orbital velocity (even though its center of mass is stationary relative to the ground) that it will feel no gravitational force and hover.
The final concluding sentence of http://arxiv.org/PS_cache/gr-qc/pdf/9909/9909014v1.pdf" says: "We can thus tell our students with confidence that kinetic energy has weight, not just as a theoretical expectation, but as an experimental fact." I interpret Carlip's statement to mean that a horizontally moving particle has greater kinetic energy than a non horizontally moving particle and therefore a weighs more and requires a greater compensating force to maintian a constant altitude, which is the answer to the question posed in the OP.
@cos. I will look at your analogy when I have more time although it seems to be a big diversion from your original question in the OP and perhaps deserves its own thread. Briefly:
The average density of the universe is probably quite low (something like one atom per cubic meter on average). I assume you really meant a density equivalent to the entire universe sqeezed into a single point with zero volume?
For what it worth, I think your original question about mass dilation and the force of gravity is a very good question, that has exposed some fundamental differences of opinions here and it might be better to focus on that and clear that issue up.
  • #67
I do not "think", I have proven it by showing the exact equations (see Rindler).
Moreover, I have also pointed out that the curving of the trajectories, be it at LHC or in our CRTs is not a function of "relativistic mass" (see the OP title) but a result of the magnetic field of the Earth via the Lorentz force (see the reference to de-gaussing).
Physics is not decided by voting. Besides, the only members of this forum that are still going against the cold facts of Rindler's math (which can also be found in MTW, BTW) is you and cos.
No, we all agree that "energy gravitates". That is not the point.
  • #68
That is not a bad interpretation . Unfortunately it is not supported by the equations of motion I posted some time ago. One simple reason is that , simplistically speaking, a body moving at a higher tangential speed is subjected to a higher centrifugal force. The Euler-Lagrange formalism I presented takes this into consideration, yours doesn't.
  • #69
I've done a down-and-dirty back-of-the-envelope calculation that *seems* to indicate that this is true.
Actually, I think that the equation that you posted might support this view. I want to do a more detailed calculation for a massive particle moving at a substantial fraction of the speed of light in the weak gravitational field of the Earth. With certainty, I won't have time to work on this calculation tonight. I'm not sure, but I might give it a go tomorrow.
  • #70
I sincerely doubt it but I would be interested in seeing your calculations, the mass of the moving object does not affect its equation of motion.
12K
9K
  • Beyond the Standard Models
