eyad-996
- 18
- 2
An object moving at the speed of light will be mass-less or will it have infinite mass??
eyad-996 said:An object moving at the speed of light will be mass-less
eyad-996 said:or will it have infinite mass??
eyad-996 said:An object moving at the speed of light will be mass-less or will it have infinite mass??
eyad-996 said:The two answers gave contradicting answers!?
The second answer gave an interesting information about resistance building up until it reaches near infinity, if the first answer was the correct one how do you reply to the building-up-infinite-resistance answer.
eyad-996 said:So a non-photon object moving at the speed of light has no mass, but photons have infinite mass?
eyad-996 said:I feel so stupid.
eyad-996 said:I should have mentioned that I'm a student in high school, I don't know much about physics, I just really really like it !
eyad-996 said:You shouldn't explain again, I'll do more research, if I had any questions Physics Forums will be the first thing I go to.
1977ub said:If you attempt to move an object with mass up to the speed of light, it will put up increasing resistance as if its mass were increasing toward infinity. A photon, with no mass, could not be slowed down by you from the speed of light.
m4r35n357 said:if you push on an object you are pretty much in its frame of reference
PeterDonis said:Not necessarily. For example, suppose you push on it with a big laser that pushes on a laser sail attached to the object. You can stay stationary as you fire the laser, while the object moves faster and faster relative to you.
m4r35n357 said:Is this really true? AIUI if you push on an object you are pretty much in its frame of reference, so it will not appear to get heavier, shorter, or experience any time shifts relative to you. So how does it put up increasing resistance?
"colloidal hydron"? I think you mean "hadron collider"! And yes, protons gain mass. That has been measured (indirectly by measuring the motion of objects the protons hit) and the mass gained is what is given by relativity.apurvmj said:protons have mass, when we accelerate them in large colloidal hydron like thing, does protons gains mass?
thanks.
You have to be a little careful with mass. In relativity there are two different definitions of mass which are in common use. So you can get different answers when different respondents use different definitions.eyad-996 said:The two answers gave contradicting answers!?
