Calculating Mass of Soil Scooped in 0.009 m3
  • Thread starter Thread starter ExoP
    Mass Soil
To calculate the mass of soil that a scoop can hold, the volume of the scoop (0.009 m³) is multiplied by the density of the soil (1400 kg/m³). This results in a mass of 12.6 kg for the 0.009 m³ scoop. The discussion also explores how to calculate the mass for different volumes, emphasizing that the weight can be determined by scaling the density accordingly. The concept of a square scoop is clarified by comparing it to a box with defined dimensions. Overall, the calculation process is straightforward once the volume and density are established.
ExoP
Hi,
I really need help with a problem. I have a plate and need to calculate how much soil it can dig.
3. The Attempt at a Solution [/b
I first calculated the volume of the scoop (a square scoop) and after that I'm stuck. Anyone have an idea?
Volume of scoop: 0.009 m3 (I calculated this)
density of soil: 1400 kg/m3
How much soil can it hold?
If the volume were 1 m3, how many kg of soil would go in ?
If it were 0.1 m3 ? 0.2 ? 0.01 ? 0.009 ?
How can a square scoop have a volume ?
Hey, you were my 1000 th p: ! Congrats!
That's true. Well, imagine a box with no top. It has a thickness, width, length and height.
From that, how am I going to calculate how much soil it can contain? Maybe should start with that
hehe, np
I still don't understand where you encounter a problem here: You have a volume and you have a weight per unit volume, so calculating the weight of this particular volume is straightforward. Right ?
If 1 m3 weighs 1400 kg, how much does 2 m3 weigh? And 0.5 m3 ? 0.1 m3 ? 0.2 ? 0.01 ? 0.009 ?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
