Is a matched filter the key to optimal radar performance?
  • Thread starter Thread starter gkraju
    Filter Radar
A matched filter is crucial for optimizing radar performance by ensuring the received echoes closely match the transmitted pulse shape. Its primary function is to minimize noise while maximizing the signal-to-noise ratio and resolution, thereby reducing inter-symbol interference. Effective radar systems balance pulse shaping between the transmitter and receiver to achieve optimal performance. If pulse shaping is concentrated solely at the transmitter, it can lead to excessive noise at the receiver, while focusing it only at the receiver requires unnecessary power at the transmitter. Overall, a matched filter enhances radar signal clarity and efficiency.
gkraju
can anyone please explain me matched filter in detail ?
my understanding is as follows ( in case of a radar).
u transmit a signal and during reception have a filter in ur receiver which continously checks in the received echoes whether the echo has the same shape of the transmitted pulse.
is it the same purpose of matched filter ?
The point of a matched filter is usually to ensure that the noise admitted into a system is minimal whilst also keeping the inter symbol interference (or, I suppose, 'resolving power', for radar) optimal.
You want the best overall sig to noise ratio and the best resolution (lowest distortion) and sharing the filtering 'equally' between transmit and receive is often reckoned to be the best way.
Or, putting it another way: If you have all your pulse shaping at the transmitter then the receiver has to admit too much noise and if you have it all at the receiver, the transmitter will be transmitting more power than necessary.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
