Math Challenge - July 2021
93 replies · 17K views · last reply
Infrared said:
Can you clarify what is not rigorous? I don't see why Q choosing b=0 is not covered by what I wrote. I wrote that P chooses any value of b such that the graph x3+bx is not tangent to y=−c. Hence if b=0 any nonzero value of c works as the line y=0 is the only horizontal that's tangent to the graph of x3. This procedure works because p(x) having a multiple root at x=a is equivalent to the graph of p being tangent to the y-axis at
I don't understand what you're saying?
How can the equation ##y=x^3+c## have three different real roots for any value of ##c##?
kshitij said:
But I applied ##A.M \geq G.M## on $$(z-x+y)(z+x-y)(x+y-z)(x+y+z)$$
##(z-x+y),(z+x-y),(x+y-z)## and ##(x+y+z)## aren't necessarily positive right?
Also to answer your questions in post #12, I have no idea about the geometric meaning of ##A.M \geq G.M##
All I knew was that if we had ##n## positive numbers, ##a_1,a_2, ... ,a_n## we can use ##A.M \geq G.M## and the equality holds if ##a_1=a_2= ... =a_n##
Sure. That gives you an upper bound. But why is it the maximum, and not way greater than the maximum?
All I knew was that if we had ##n## positive real numbers, ##a_1,a_2, ... ,a_n## we can use ##A.M \geq G.M## and the equality holds if ##a_1=a_2= ... =a_n##
I added the condition ##x,y,z > 0## to save us a zoo of cases. That leaves us with fewer cases. Sorry for this inconvenience.
I meant the geometrical meaning of ##f(x,y,z)## not the meaning of mean values.
I don't know about why is that maximum, if equality holds then they should be maximum. I think I don't understand what you're trying to say?
Also even if ##x,y,z \gt 0##, ##x+y-z## can still be less than zero and we cannot use A.M G.M inequality the way I did, if ##x,y,z## were sides of a triangle then its different though.
fresh_42 said:
I meant the geometrical meaning of f(x,y,z) not the meaning of mean values.
I just noticed that $$c(c-2x)(c-2y)(c-2z)$$
Looks similar to the formula for area of a triangle!
Is that what you meant, is geometrical meaning of ##f(x,y,z)## is that is 16 times the square of the area of a triangle with sides ##x,y,z##! because area of a triangle with sides ##x,y,z## will be
$$\sqrt{\dfrac{c}{2}\left(\dfrac{c}{2}-x\right)\left(\dfrac{c}{2}-y\right)\left(\dfrac{c}{2}-y\right)}$$
Infrared said:
Can you clarify what is not rigorous? I don't see why ##Q## choosing ##b=0## is not covered by what I wrote. I wrote that ##P## chooses any value of ##b## such that the graph ##x^3+bx## is not tangent to ##y=-c.## Hence if ##b=0## any nonzero value of ##c## works as the line ##y=0## is the only horizontal that's tangent to the graph of ##x^3.## This procedure works because ##p(x)## having a multiple root at ##x=a## is equivalent to the graph of ##p## being tangent to the ##y##-axis at ##x=a.##
You started with ##P## chooses ##a=0##. And if ##Q## answers ##b=0,## then ##P## is left with ##x^3+c##. So ##a=0## is no winning strategy for ##P##.
kshitij said:
Infact, I thought that the winning strategy for P would be choosing the value of b as a negative number in the first move, so if Q chooses a value of a in the next move P can simply shift the x-axis up or down accordingly so as to intersect the curve at three points by choosing the value of c and if Q chose the value of c in the second move to make the curve lie above axis or below such that it doesn't cut it at three distinct points then P can choose the value of a accordingly to shift the curve either up or down because a is the coefficient of x2 so it should have a greater say in the position of the curve in the plane and it is also the last move so Q cannot do anything after this.
Could you write this in formulas? It leaves all the work for me to do, only to decode this string.
Yes, that's the idea! You have proven ##f(x,y,z) \leq C## for some specific value ##C##. But if the maximum would be ##f(x,y,z)=:M<C## then ##C## doesn't answer the question. You must show that ##C## is the least possible solution, a maximum, not only an upper bound.
But it leaves us with fewer cases. The original theorem was about triangles, but the problem has an answer in any case. Many of them, I admit, so I reduced them significantly now by demanding ##x,y,z > 0##.
I think I have just a strategy but I am not sure because let's say that P plays according to my strategy and chooses a negative value of ##b## say ##b=-1## but then after Q chose a value of ##c## then I don't know what value of ##a## P should choose, I know (more like I feel) that there are some values of ##a## that he can choose but I don't have any relation like $$a \geq f(b,c)$$
I can maybe think about that problem later but first let me focus on #13
fresh_42 said:
Yes, that's the idea! You have proven f(x,y,z)≤C for some specific value C. But if the maximum would be f(x,y,z)=:M<C then C doesn't answer the question. You must show that C is the least possible solution, a maximum, not only an upper bound.
Are you saying that I must prove why the equality holds? or do you want me to show when the equality holds?
As I said that for ##a_1,a_2, ... ,a_n##, ##A.M=G.M## when ##a_1=a_2= ... =a_n##
So in our case the equality should hold if $$x+y+z=x+y-z=x-y+z=y+z-x$$
But this equality will only hold true if ##x=y=z=0##, is that the answer? is maximum value of ##f(x,y,z)=0##?
But if ##f(x,y,z)## is area of a triangle then ##f(x,y,z)=0## is the least possible value not the maximum value, surely this is wrong!
Also I forgot that ##x,y,z \gt 0## so ##x=y=z=0## cannot be correct anyway.
I will try again this problem later.
I am saying that any upper bound is not sufficient. We are looking for the maximum. We get from your calculation and the fact that ##A.M.=G.M.## is possible, that ##f(x,y,z)## is maximal for ##c-2x=c-2y=c-2z,## i.e. ##x=y=z##. Hence we obtain the maximum at ##x=y=z=c/3## with a maximum function value ##c^4/27.##
You simply should have mentioned the conclusion. It is necessary that ##A.M.=G.M.## can be obtained since otherwise we only have an arbitrary upper bound.
In case ##x,y,z## are the sides of a triangle, it is the theorem of Heron which says that ##f(x,y,z)=16\,F^2## where ##F## is the area of the triangle with side lengths ##x,y,z, ## i.e. the triangle with the maximal area by constant circumference is an equilateral triangle.
StoneTemplePython said:
Probably a good idea to put a pin in this.
I love the idea and want to understand it. I just thought you could help me a bit to follow you.
fresh_42 said:
I apologize that I am not familiar with your nomenclature. I guess I wouldn't have asked if it had been ##\mathbf{1}\cdot \mathbf{1}^\tau##. The ambiguous use of ##T## is of course totally ok.And a note that this was the defining equation and not a conclusion was obviously not necessary. Sorry for not guessing it.
I would ask what ##G'## means instead of guessing ##G':=\operatorname{im} \phi ,## but you are obviously annoyed by my lack of fantasy. And sure, it is not necessary to mention that ##G'## isn't ##[G,G]## in a proof in group theory. Or is it, and I missed the point again?I thought of an example like ##T=\dfrac{1}{3}\cdot \begin{bmatrix}
1 & 1 & 0&\ldots\\1&1&0&\ldots\\0&0&1&\ldots\\ &&&\ddots \\ 0&0&\ldots&1
\end{bmatrix}## where I could make the matrix arbitrary large. This example doesn't fulfill ##\operatorname{trace}T =1##. Hence this condition restricts the number of possible groups ##H## significantly, and the question whether some groups remain is not trivial. You have always the identity in ##H## which can be made arbitrary large, regardless how large ##|H|## is. Sorry for asking.
Look, I am not annoyed at you-- I can remember what it is like to get a response to these challenge questions that is just baffling. So I put myself in your place and I get it. But I am trying hard (and thus far failing) to not get bogged down in lots of details. FWIW I almost wrote ##\mathbf {11}^*## as conjugate transpose seems reasonable over ##\mathbb C##-- probably better notation. And yes your definition of ##G'## is a lot cleaner.
The point of that Artin exercise btw is that for any complex finite matrix group, when you sum over the group, the instances of the trivial representation survive (obvious) and all other irreducible representations are killed by the summation (surprising to me). So Burnside's Formula is just counting the number of trivial representations and each orbit has exactly one trivial rep associated with it. (If we take this view point, we can bypass character theory altogether though I'm not sure whether that is desirable).
Let me see. After some sleep: I think @Office_Shredder has come up with a way for me to radically streamline it and cut out everything in the "General Case". I've already shown (convincingly?) that in the Base Case: if you average over ##G'## that ##\text{trace}\big(T\big)=1\implies \text{ G is transitive}##. Now I need to show that ##\text{ G is transitive} \implies \text{trace}\big(T\big)=1 ##. (Should take at most 3 lines to prove). I think that will give "each orbit has exactly one trivial rep associated with it". The finish then should be something like the action of ##G## on ##X## may be decomposed into a partition of orbits so if the Burnside Fromula gives you ##m## there must be ##m## orbits.
Problem #4:
First say ##n = p## where ##p## is prime. Then ##d = \{ 1 ,p \}## and we have:
\begin{align*}
\sum_{d|n} \sigma (d^{k-1}) \varphi (d) & = \sigma (1^{k-1}) \varphi (1) + \sigma (p^{k-1}) \varphi (p)
\nonumber \\ & = 1 + (1 + p + p^2 + \cdots p^{k-1}) (p-1)
\nonumber \\ & = 1 + (p^k - 1) =p^k .
\end{align*}
Which proves the result when ##n## is equal to one prime number. We will prove the general result by induction. Let ##n = p_1 p_2 \cdots p_\ell## (where no two primes are the same). Assume
\begin{align*}
\sum_{d|n} \sigma (d^{k-1}) \varphi (d) & = n^k
\end{align*}
Now Let ##n' = n p_{\ell+1}## (where ##p_{\ell+1} \not= p_j## for ##1 \leq j \leq \ell##), then the divisors of ##n'## are the divisors of ##n## together with all the divisors of ##n## multiplied by ##p_{\ell+1}##. So that:
\begin{align*}
\sum_{d|n'} \sigma (d^{k-1}) \varphi (d) & = \sum_{d|n} \sigma (d^{k-1}) \varphi (d) + \sum_{d|n} \sigma (d^{k-1} p_{\ell + 1}^{k-1}) \varphi (d p_{\ell + 1})
\nonumber \\
& = n^k + \sum_{d|n} \sigma (d^{k-1}) \varphi (d) \sigma(p_{\ell + 1}^{k-1}) \varphi (p_{\ell + 1})
\nonumber \\
& = n^k + n^k [(1 + p_{\ell+1} + p_{\ell+1}^2 + \cdots + p_{\ell+1}^{k-1}) (p_{\ell + 1} - 1)]
\nonumber \\
& = n^k + n^k [p_{\ell+1}^k - 1]
\nonumber \\
& = (n p_{\ell+1})^k = {n'}^k
\end{align*}
where we have used the inductive assumption, and that both ##\sigma## and ##\varphi## are multiplicative.
julian said:
Problem #4:
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
\begin{align*}
\nonumber \\
\nonumber \\
\nonumber \\
\nonumber \\
\end{align*}
Alternative to an induction, you can prove that the function ##F(n):=\sum_{d|n}f(d)=\sum_{d|n}\sigma(d^{k-1})\varphi(d)## is also multiplicative:
\begin{align*}
F(ab)&=\sum_{d|ab}f(ab)= \sum_{d|a}\sum_{e|b} f(a)f(b) =\sum_{d|a}f(a) \sum_{e|b} f(b) =F(a)F(b)
\end{align*}
Office_Shredder said:
Edit:
For 3, did you really mean a lie algebra isomorphism? I thought the general linear algebra was not semismple. Did you just mean an embedding?
Sorry I think this got lost in the shuffle, I intended to direct this question to @fresh_42
This is due to the ambiguous use of the English language in this case. I had to learn here on PF that monomorphisms are called isomorphisms into. I personally hate this, and it is well distinguished in German: either it is a monomorphism or an isomorphism, not such a stupid thing as an isomorphism into. But who am I to argue with native speakers? I tried to clarify this stupid use of terms by writing an embedding arrow.
The dimensions alone forbid an isomorphism, even for non semisimple Lie algebras.
Ado's theorem says it can always be done over a field characteristic zero, but it is especially easy to see for semisimple ones.
Yes, sorry if I was harsh. It is also a matter of time. I read your solution late at night, or was it early in the morning? so it was more difficult to decode than after sleep. But anyway, I had learned group characters long ago, so I first have to refresh my memory.
Oops, I somehow missed the adjective "real" in the question! I guess I should've realized it was a little too easy.
I still think ##P## can win, so I'll try again. Let ##f(x)=x^3+ax^2+bx+c.## First ##P## chooses ##b=-1##. Note that this ensures that the discriminant of ##f'(x)=3x^2+2ax+b##, which is ##4a^2-12b## must be strictly positive positive, so ##f## has two distinct critical points, the smaller of which must be a local maximum, and the larger of which a local minimum (no matter the value of the other coefficients). If ##Q## selects a value for ##a##, then ##P## wins by selecting any value of ##c## such that ##-c## is between the local maximum and local minimum values of ##x^3+ax^2+bx.##
Now consider the case that ##Q## selects a value for ##c##. Let ##x_-## and ##x_+## respectively represent the smaller and larger critical points for ##f(x).## Let ##g(x)=x^3+ax^2+bx## (so we forget the constant term in ##f##; this is not yet fully defined since we need to pick ##a##) For ##P## to win, we need a strategy to choose ##a## in such a way that ##-c## lies between ##g(x_+)## and ##g(x_-).##
Applying the quadratic formula to ##g'(x)## we find that ##x_-=-2a/3+O(1/a)## in the limit ##a\to\infty## and similarly ##x_+=O(1/a).## Hence ##\lim_{a\to\infty}g(x_-)=\infty## and ##\lim_{a\to\infty}g(x_+)=0.## Thus if ##-c## is positive, then ##P## can win by choosing a sufficiently large value of ##a##. Analogously, if ##-c## is negative, ##P## can win by choosing a sufficiently negative value of ##a.## Finally if ##c=0##, then ##P## may choose ##a=0## since ##x^3-x## has three distinct roots.
Let me know if this looks better @fresh_42.
\begin{align*}
f'(x)=0&=3x^2+2ax-1 \\&\Longrightarrow 0=x^2+\dfrac{2a}{3}-\dfrac{1}{3}\\&\Longrightarrow x_{1,2}=-\dfrac{a}{3}\pm \sqrt{\dfrac{a^2}{9}+\dfrac{1}{3}}=-\dfrac{a}{3}\pm \dfrac{1}{3}\sqrt{a^2+3}
\end{align*}
which is always a positive discriminant.
Infrared said:
so ##f## has two distinct critical points, the smaller of which must be a local maximum, and the larger of which a local minimum (no matter the value of the other coefficients). If ##Q## selects a value for ##b##,
How? ##P## already set ##b=1##.
Hint: It is surprisingly easy if you do not want to enforce a win by the first move!
Yep, this is the point!
Apologies this should say ##a## instead of ##b.##
I still think ##P## can win, so I'll try again. Let ##f(x)=x^3+ax^2+bx+c.## First ##P## chooses ##b=-1##. Note that this ensures that the discriminant of ##f'(x)=3x^2+2ax+b##, which is ##4a^2-12b## must be strictly positive positive, so ##f## has two distinct critical points, the smaller of which must be a local maximum, and the larger of which a local minimum (no matter the value of the other coefficients). If ##Q## selects a value for ##b##,
Let me assume you meant that ##Q## sets a value for ##a##. Then ##P## can choose ##c## in a way that ##f## intersects the ##x-##axis three times.
Which is ##3x_-=-a-\sqrt{a^2+3}## and ##3x_+=3x_-=-a+\sqrt{a^2+3}.##
Which is ##g(x)=f(x)-c=x^3+ax^2-x.##
Why? Do you mean ##x=-c##, ##f(x)=-c##, or ##g(x)=-c##?
Infrared said:
Applying the quadratic formula to ##g'(x)## we find that ##x_=-2a/3+O(1/a)## in the limit ##a\to\infty## and similarly ##x_+=O(1/a).##
Why don't we have ##x_{\pm} = -\dfrac{a}{3}\pm \sqrt{\dfrac{a^2}{9}-\dfrac{1}{3}}= O(a)## because ##g'(x)=f'(x)=3x^2+2ax-1\,\rm ?##
How do you get ##a## into the denominator?
I mean that ##P## wins if they can choose ##a## such that ##g(x_+)<-c<g(x_-).## If this holds, then the equation ##g(x)=-c## (which is ##f(x)=0##) has three solutions: one between ##x_-## and ##x_+##, one larger than ##x_+##, and one smaller than ##x_-.##
We have $$x_-=-a/3-\sqrt{a^2/9-1/3}=-a/3-a/3\sqrt{1-3/a^2}=-a/3-a/3(1+O(1/a^2))=-2a/3+O(1/a).$$ The other term is similar. You're right (up to signs) that this term is also ##O(a)## but that isn't precise enough to conclude that ##g(x_-)## becomes very positive in the limit ##a\to\infty.##
Ok, I finally got it. It took so long and several posts that I post my solution as reference:
##P## has the following winning strategy:
##P## chooses ##c=1## in his first move. In case ##Q## sets a value for ##a##, then ##P## finally sets ##b < -a-2\,;## whereas in case ##Q## sets a value for ##b##, ##P## finally sets ##a<-b-2\,.##
We now have to show that the equation has three distinct real roots. Let ##f(x)=x^3+ax^2+bx+1\,.## Since ##\lim_{x \to \infty}f(x)=+\infty## and ##\lim_{x \to -\infty}f(x)=-\infty## there is a real number ##k>1## such that
f(k)> 0\, , \,f(0)=1\, , \,f(-k)<0\, , \,f(1)=a+b+2 < 0
By the mean value theorem, there have to be roots ##f(\xi_j)=0## with
-k <\xi_1 <0 < \xi_2 < 1< \xi_3< k
So, basically as I understand it,
we had $$f(x,y,z)=c(c-2x)(c-2y)(c-2z)$$
And ##c## is a constant, so we use ##A.M \geq G.M## on $$g(x,y,z)=(c-2x)(c-2y)(c-2z)$$
So, we get,
\begin{align*}
\dfrac{(c-2x)+(c-2y)+(c-2z)}{3} &\geq \left((c-2x)(c-2y)(c-2z)\right)^\frac1 3\\
\dfrac{3c-2c}{3} &\geq \left((c-2x)(c-2y)(c-2z)\right)^\frac1 3\\
\dfrac{c^3}{27} &\geq (c-2x)(c-2y)(c-2z)\\
\end{align*}
And the equality holds when,
$$c-2x=c-2y=c-2z$$
Which gives us ##x=y=z## which is condition for an equilateral triangle, and
$$f(x,y,z)=\dfrac{c^4}{27}$$
And we know that 16 times the square of the area of an equilateral triangle with side length ##a## and perimeter ##c## is,
$$16\left(\dfrac{\sqrt {3}a^2}{4}\right)^2=3a^4=\frac{c^4}{27}$$
Which is the same result that we got!
So, we get,
\begin{align*}
\dfrac{c^3}{27} &\geq \left((c-2x)(c-2y)(c-2z)\right)\\
\end{align*}
$$c-2x=c-2y=c-2z$$
When I first used ##A.M \geq G.M## on$$f(x,y,z)=c(c-2x)(c-2y)(c-2z)$$
the equality would never hold because if $$c=c-2x=c-2y=c-2z$$
then we would get $$x=y=z=0$$ which was not possible
We now have to show that the equation has three distinct real roots. Let ##f(x)=x^3+ax^2+bx+1\,.## Since ##\lim_{x \to \infty}=+\infty## and ##\lim_{x \to -\infty}=-\infty## there is a real number ##k>1## such that
I didn't knew there were multiple winning strategies for ##P##!
Also, couldn't we generalise that further for when ##P## chooses any value of ##c## in the first move, then the condition for $$f(1)<0$$ would change to $$a+b+c+1<0$$
So if ##Q## chooses a value of ##a## then ##P## would choose ##b## such that $$b<-a-c-1$$ And if ##Q## chooses ##b## then ##P## should make sure that $$a<-b-c-1$$
Edit: I realized that this wouldn't work because we would have to show that $$f(c)<0$$
You have to apply the inequality on ##c-2x,c-2y,c-2z## and leave out ##c##.
Probably. But ##c=1## makes the argument easier to read.
