Math software for checking solutions and proofs?
  • Thread starter Thread starter abelgalois
    Proofs Software
The discussion centers around the challenge of finding software that provides detailed proofs and solutions for precalculus and calculus problems, particularly when textbooks only offer answers to odd-numbered questions without showing the work. Two software options mentioned are Mathematica and Maplesoft, with a note that Maple may offer step-by-step solutions for differentiation and integration through its tutor feature, but not for other areas. The user expresses disappointment with the lack of detailed solutions in the "Principles of Mathematics" textbook by Oakley, especially when compared to Sullivan's "Algebra and Trigonometry." The conversation highlights the expectation for students to understand and prove mathematical concepts independently, referencing the complexity of the quadratic equation introduction in Oakley's book. Suggestions for additional resources include older editions of textbooks with more detailed answer books and Schaum's outlines, as well as Maxima, a free computer algebra system that, while not providing proofs, can assist in exploring mathematical problems.
abelgalois
Hello guys, I don't know where else to post this but here goes.
I'm going to be catching up on a looot of math this year. Unfortunately a lot of the math books that I'll be using only provide the answers to odd numbered questions. And the answers that they do provide a lot of the times "do not show the work". Is there software out there that will provide detailed proofs and solutions to most precalculus-calculus math problems?
Thanks.
Neither will provide a step by step solution. I think Maple might, actually if you use the tutor but that's only for differentiation and integration, last time I checked. I don't think it'll do anything else though.
Ah thanks. It looks like I'll have to rely on the good people on the homework forum to check key proofs.
I'm genuinely sad that "Principles of Mathematics" by Oakley doesn't have may detailed solutions to its 2300 or so problems. I actually compared the book with Sullivan's "Algebra and Trigonometry" and the differences between the two was startling. In Sullivan's text one of the first things you learn about quadratics is how to solve a quadratic equation by factoring. In "Principle's of Mathematics" quadratic equations are introduced like this:
"Earlier we saw that the quadratic equation x^2 = 2 could not be solved
in the field of rational numbers and that x^ 2 = -1 could not be
solved in the field of real numbers. Thus it is clear that the axioms
of a field are not strong enough to assure that every solution of
every quadratic equation . It was the reason that we invented the
field of complex numbers, in which every quadratic equation has a
solution. In order to prove this consider the equation:
ax^2 + bx + c = 0"
And then it derives theorems and proofs based on that. So we're actually expected to follow the chains of reasoning which led to this conclusion or that. And we're expected to understand them by proving certain things ourselves.
I can't believe this book is 70 years old... I think if I do every single problem in this book, Courant or Apostol will be a breeze.
Not sure of your level, but there are answer books available for many intro-level Math texts (Calc, Linear Algebra, ODEs) that give more detail for the answers than the ones at the back of the book. You can find many of the older editions for very cheap 2nd hand. Some Schaum's outlines contain a lot of worked proofs as well, but you have to watch for errors.
Maxima is a free (GPL) computer algebra system somewhat like Maple. Although it will not do any proofs, it can be useful for exploring aspects of math that can be tedious by hand.
http://maxima.sourceforge.net/
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
10K
