Mathematica does not like hyperbolic functions
2 replies · 7K views · last reply
blalien
[SOLVED] Mathematica does not like hyperbolic functions
So, consider the equation cosh(x)=n*x
For a given n, the equation has 0, 1, or 2 possible values of x. If n is below the critical value, the equation has no solutions. If n is above the critical value, the equation has two solutions. And if n is exactly the critical value, the equation has one solution. My goal is to use Mathematica to show that the critical value is approximately 1.51.
Theoretically, the line Length[Solve[Cosh[x] == n*x, x]] should give the number of solutions for a given n. Then I can make a table of n's and find the point where the number of solutions goes from 0 to 2.
Unfortunately, I keep getting the error:
Solve::tdep: The equations appear to involve the variables to be solved for in an essentially non-algebraic way.
NSolve has the exact same problem. FindRoot always gives exactly one solution, whether there are zero or two solutions to the equation. Is there a way to make Mathematica more cooperative, or another way to go about this problem? Since the TI-89 can handle this problem (but is too slow to be useful), it seems like Mathematica should be able to as well.
Thanks for your help!
Since [itex]\cosh x[/itex] and [itex]nx[/itex] have one intersection point, their derivatives are equal. Along with the original equation, this gives two equations for the two unknowns [itex]n[/itex] and [itex]x[/itex] (at intersection).
[tex]\sinh x = n[/tex]
[tex]\cosh x = nx.[/tex]
Divide these equations and get
[tex]tanh x = \frac{1}{x}.[/tex]
Solve this numerically for [itex]x[/itex] (use only the positive solution), and, to find [itex]n[/itex], plug this solution into the top equation.
