Mathematica [Mathematica] NIntegrate Piecewise function with DE solution
The discussion centers on solving a differential equation (DE) and using its solution within a piecewise function for numerical integration. The user initially encounters an issue with the NIntegrate function, which fails to compute due to the output of NDSolve being a list. The solution involves modifying the function definition to extract the first element from the list produced by NDSolve. After implementing this change, the user successfully integrates the piecewise function, yielding a result of 3.5. The key takeaway is the importance of correctly handling the output format of NDSolve when defining subsequent functions for integration.
jackmell
Hi,
I'd like to solve a DE, create a function with the solution, then use that solution in a Piecewise function, and then NIntegrate the Piecewise function but I can't get NIntegate to work. Here's what I'm trying to do:
Code:
mysol = NDSolve[{y'[x] == x, y[0] == 1}, y, {x, 0, 1}]
myy[x_] := Evaluate[y[x] /. mysol];
myf[x_] := Piecewise[{{myy[x], 0 < x <= 1}, {x^2, x > 1}}];
NIntegrate[myf[x], {x, 0, 2}]
NIntegrate then tells me it's not numeric in the interval.
Can someone explain to me what I'm doing wrong?
Thanks,
Jack
The output of NDSolve (mysol) is a list. You need to take the first element of it in your myy function definition, as follows:
Code:
In[25]:= mysol = NDSolve[{y'[x] == x, y[0] == 1}, y, {x, 0, 1}]
In[26]:= myy[x_] := Evaluate[y[x] /. mysol][[1]];
In[27]:= myf[x_] := Piecewise[{{myy[x], 0 < x <= 1}, {x^2, x > 1}}];
In[28]:= NIntegrate[myf[x], {x, 0, 2}]
Out[28]= 3.5
Code:
Out[28]= 3.5
Ok. Thanks a bunch. It's working now. :)
