Mathematica Mathematica taking a long time to solve
  • Thread starter Thread starter haihek
    Mathematica Time
The user is experiencing excessively long computation times in Mathematica while trying to solve two complicated simultaneous equations, with the process running for over six hours. Suggestions include simplifying the equations by substituting expressions to reduce their size, which can significantly improve run time. It is noted that the complexity of the equations can lead to lengthy calculations, potentially indicating that an analytic solution may not exist. Assigning assumptions about the variables can also help speed up the solving process. Overall, users are encouraged to simplify their equations and consider assumptions to enhance performance.
haihek
Hi everyone,
I am trying to solve this complicated two simultaneous equations, and it has been taking more than 2 hours to solve .. and it is still running... can anyone tell me what is wrong .. thanks
Solve[{((((1 - xr)/xr)^(1/2) (M2^2 xr - 1)/(
1 + (gam + 1)/2 M2^2 - M2^2 xr)) - (((1 - xm)/xm)^(1/2) (
M1^2 xm - 1)/(1 + (gam + 1)/2 M1^2 - M1^2 xm)))/(
1 + (((1 - xr)/xr)^(1/2) (M2^2 xr - 1)/(
1 + (gam + 1)/2 M2^2 - M2^2 xr)) (((1 - xm)/xm)^(1/2) (
M1^2 xm - 1)/(1 + (gam + 1)/2 M1^2 - M1^2 xm))) == tanthi,
xm - a xr == b}, {xm, xr}]
Try to solve xm in terms of xr from
xm - a xr == b
then place it in the other equation, then solve just for xm.
It may do the job.
xm - a xr == b
It may do the job.
Thank you for you reply, although it looked like it may do the job, but nope.. still facing the same waiting time. I don't know if it is normal to take that long (6 hours now), because i never faced this type of run before. Should i just keep it running? or is it a sign of calculation failure??
Disclaimer: This is somewhat user superstition.
It seems that when Solve is given "complicated equations" that the size of the expression has a serious effect on the run time. Doing what is possible to reduce the size of the expressions seems to help.
Notice that gam always appears as (gam + 1)/2 in your expression. Substituting using
expression/.(gam + 1)/2->g
will reduce the size and not change the results.
If I have not made any mistake then the smallest I have been able to make your expression is
(-(Sqrt[-1 + 1/xm]*(-1 + M1^2*xm)*(1 + M2^2*(g - xr))) + (1 + M1^2*(g -
xm))*Sqrt[-1 + 1/xr]*(-1 + M2^2*xr))/((1 + M1^2*(g - xm))*(1 + M2^2*(g -
xr)) - Sqrt[-1 + 1/xm]*(-1 + M1^2*xm)*Sqrt[-1 + 1/xr]*(-1 + M2^2*xr))
That is about 2/3 the size of your original and does not incorporate the other
suggestion of substituting for one of the xm or xr.
Its a sign of the solution probably having no analytic form, or at least a really crazy one.
It helps to assign some assumptions sometimes, especially when sqrts are involved. Are the M's or xm's or a/b positive? real? less than/gt one? These things can help speed things up:
$Assumptions = b>0&&a>0&&0<=xm<=1
etc.
thank you guys for your replies
