MATLAB function within function handle output
13 replies · 3K views · last reply
Carter
MATLAB
The funciton "rockdynamicstage" outputs a matrix 4 by x, where x is somthing around 300( varies).
The funciton "rockdynamicstage" is within the funciton handle "sim" with an input of gama0. (PayMass,Masstages,Massfrac,Thstage,IspStage,ChangeTstage) ar parameters that are set earlier in the code.
sim= @(gama0) rockdynamicstage(gama0,PayMass,Masstages,Massfrac,Thstage,IspStage,ChangeTstage);
I need the "sim" to output the last element in the 4th row of the "rockdynamicstage". So that I get the last element in the 4th row in "rockdynamicstage" for a range of gama0s.
How would I output it.
I tried doing
sim= @(gama0) rockdynamicstage(gama0,PayMass,Masstages,Massfrac,Thstage,IspStage,ChangeTstage)(4,end);
similar to when using a regular matrix
x= @(gama0) rockdynamicstage(gama0,PayMass,Masstages,Massfrac,Thstage,IspStage,ChangeTstage);
sim=x(4,end);
Or you can change the rockdynamicstage function
sim=x(4,end);
But I need it to be a function handle. I need to be able to plug the function "sim" (that would ideally output the last element in the 4th row for a range of gama0s) into another function that finds the zero point.
So essentially I need the function handle to output a (x,2) array of the gama0s and the 4th row last elements for the rockdynamicstage.
output from the "sim" (or what you have as x) needs to be
[ gama01, rockdynamicstage(4,end); gama02, rockdynamicstage(4,end); gama03, rockdynamicstage(4,end);...so on]
well if you want to make it very complicated then you need to change rockdynamicstage
you can use a simple for loop to move between cases, calling sim at each gama value
This essentially is the outline but myrocketsim is rockdynamicstage. And the bisection method is used to find the zero
There is a key difference between the code you presented and the code in step 2
What would that be?
Carter said:
What would that be?
Is it the "get()" part
donpacino said:
I didn't realize get could extract elements of a matrix
that syntax "get()" doesn't work though
get is designed to work with objects. My guess is you are supposed to define myrocket sim (or equivalent) as an object
Do you know for sure that your professor requires this architecture. It could be done very easily by using a loop or modifying the function calls.
If not you need to modify the way your myrocketsim works
