MATLAB Matlab transfer function problem
The user is experiencing issues with defining a transfer function H(s) in MATLAB, where the expression H(s) = L(s)/(1+L(s)) yields unexpected results, such as additional poles and zeros. The correct formulation should be H(s) = A(s) / (B(s) + A(s)), which can be achieved using MATLAB's tfdata function. The user suggests that the problem may stem from the way Ls is defined, noting that the syntax used may not be valid in MATLAB. A proper definition of Ls is recommended to ensure accurate calculations. Ultimately, the discussion highlights potential pitfalls in MATLAB's handling of transfer functions and the importance of correct syntax.
MechatronO
I have a transfer function
L(s) = A(s)/B(s)
that I call Ls.
However, when defining
H(s)= L(s)/(1+L(s))
by
Code:
Ls =
  -70.6s^2 - 2003 s + 3375
   s^3 + 119.6 s^2 + 2806 s
Hs = Ls / (1+Ls)
things go wild. The highest exponent power doubles or so and I get several extra poles or zeros. What I should get is
H(s) = A(s) / ( B(s)+A(s) )
which is the exact result. This I can achieve in MATLAB by
Code:
[As,Bs] = tfdata(Ls,'v');
Hs= tf(As,Bs+As)
and the result from this are exactly the expected.
However, why won't
Code:
 Hs = Ls / (1+Ls)
work?
Are matlabs routines that bad? Or am I doing something wrong?
Is s a vector?
No,
s= tf('s');
MechatronO said:
Code:
Ls =
[/QUOTE]
This doesn't look like a valid Matlab statement to me. I would write it as
Ls = ( -70.6s^2 - 2003 s + 3375 ) / ( s^3 + 119.6 s^2 + 2806 s );
(It presumes that s has already been defined earlier.)
9K
