Why is matrix multiplication necessary for representing linear transformations?
Matrix multiplication is defined to facilitate the representation of linear transformations and solve systems of linear equations. Each matrix can be viewed as a linear transformation, with the multiplication of matrices corresponding to the composition of these transformations. This means that multiplying two matrices effectively applies one transformation after another, which can be visualized through the movement of points in a coordinate system. The rules for matrix multiplication are designed to maintain the properties of linearity, allowing for consistent results across various dimensions. Understanding this connection is crucial for studying both linear and nonlinear mathematics.
Gear300
What would be the proof for matrix multiplication?...or just an explanation as to why its done the way its done.
Mathematics news on Phys.org
It's done like that by definition, as far as I am aware. I don't really know why it's defined like that though...:rolleyes:
I see...I haven't really studied matrices all too much, so I'm not too sure of what they are (by what I can say, a matrix is a rectangular array of data or an organization of data). I'm just wondering how multiplying two rectangular arrays of data works.
They're defined to multiply in that manner so that they can be used to solve systems of linear equations. The manner of multiplication is also convenient in that it easily represents a linear transformation, which is very useful in studying nonlinear mathematics. A transformation T of two objects u and v is linear if T(s*u + v) = s*T(u) + T(v). Ie., if x is a vector denoted by a column of numbers, a linear transformation of x can always be represented by matrix multiplication from the left (Ax).
Let's think of a 2x2 matrix, which represents a linear transformation of the plane. I like to think of matrices as columns of numbers, not as rows. Then the left column of the matrix represents where the point (1,0) on the horizontal axis goes. The right column represents where the point (0,1) on the vertical axis goes.
Each time you multiply a matrix by another, you are following up one linear transformation by another. You can imagine how the (1,0) point moves after one transformation, and then how the resulting vector moves after the next. The rules for calculating products of matrices might be easier to think about that way.
More abstractly, if you think of matrices as linear transformations R^n->R^m, then matrix multiplication corresponds to composition of linear maps. So A(B(v))=(AB)(v), where AB is the matrix product. This requires and (easy) proof.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
