Mathematica Matrix Systems of ODEs - Mathematica
The discussion focuses on solving a system of linear ordinary differential equations (ODEs) using Mathematica. The user initially struggles with implementing the NDSolve function for a large set of equations in matrix form, despite being able to solve smaller systems explicitly. Suggestions include ensuring the syntax for equations and variables matches Mathematica's requirements and practicing with simpler examples before tackling the larger problem. Additionally, using MatrixExp is recommended to minimize numerical errors associated with NDSolve for constant coefficient systems. The user ultimately finds a working solution using eigenvalues and eigenvectors, confirming the equivalence to the matrix exponential method.
brydustin
Matrix Systems of ODEs -- Mathematica
I'm trying to solve the classic "systemm of linear ODEs" of the form: Y(t)' = X*Y(t)
Its homogenous, so it wouldn't hurt to rewrite it as Y(t)' - X*Y(t) = 0 (if that helps?)
so here is my attempt at the solution
solExp == NDSolve[Y'[t] == X.Y[t] && Y[0] = P, X, {t, 0, 10}]
where P is a vector of numbers (they are each fixed) -- its my list of initial conditions, because each equation is first order, each eq-n needs one initial condition.
you can imagine the situation of:
(dy1/dt)= x1,1*y1(t) + x1,2*y2(t) + ... x1,N*yN(t)
(dy2/dt)= x2,1*y1(t) + x2,2*y2(t) + ... x2,N*yN(t)
(dyN/dt) = xN,1*y1(t) + xN,2*y2(t) + ... xN,N*yN(t)
we are given the intial condition that the set Y[t=0] = P = {y1(0), y2(0),...yN(0)}
I can't seem to get this to work using matrix notation... although I know how to do it explicitly for a few equations, where you list each on in the code... the thing is: I am dealing with a LARGE set of equations and so this wouldn't be practical.
Thanks
Suggestion: First figure out all the errors you have in creating each of the arguments you are going to pass to NDSolve before you even consider using NDSolve.
In other words practice on
eqns={something}
until you get something exactly right and the result exactly matches the syntax of
http://reference.wolfram.com/mathematica/ref/NDSolve.html
for systems of equations.
Then practice on
vars={somethingelse}
until you get somethingelse exactly right and the result exactly matches the syntax of
Then you might be ready for NDSolve[eqns,vars,{t,0,10}]
Hi brydustin,
Bill's right... there's a lot wrong in your original post.
Here's a simple example of a 2*2 constant coefficient system to help get you started:
Code:
X = Array[x, {2, 2}];      (* Arbitrary constant coefficient matrix *)
Y[t_] := {y1[t], y2[t]};   (* functions to solve for *)
Y0 = {y10, y20};           (* initial conditions  *)
(*  Generate equations *)
eqns = Thread /@ {Y'[t] == X.Y[t], Y[0] == Y0}
(* Alternately use something like *)
(* eqns = And@@Flatten[Thread /@ {Y'[t] == X.Y[t], Y[0] == Y0}]  *)
(* Or *)
(* eqns = Thread[Flatten[{Y'[t] - X.Y[t], Y[0] - Y0}] == 0] *)(* Solve -- will produce a mess  *)
soln = DSolve[eqns, Y[t], t];
(*  make the output a little nicer on th eyes...  *)
soln /. x[1, 1]^2 + 4 x[1, 2] x[2, 1] - 2 x[1, 1] x[2, 2] +
    x[2, 2]^2 -> \[Delta]^2 // FullSimplify[#, \[Delta] > 0] &
Also, if it really is a system of constant coefficient 1st order DEs, then it might be better to use MatrixExp to generate the solution, this way you can minimize the numerical errors that are inevitable in the NDSolve: The following will return "True"
Code:
MatrixExp[t X].Y0 == (Y[t] /. First[soln]) // Simplify
Simon_Tyler said:
Hi brydustin,
Code:
(* Or *)
Code:
Cool! This worked, but I also tried the following:
d = Dimensions[W][[1]];
GeneralSolution = 0;
Eigen = Eigensystem[W];
m = Transpose[Last[Eigen]];
CValues = LinearSolve[Transpose[Last[Eigen]], P]; (*P is the intial condition vector*)
For[i = 0, i < d,
GeneralSolution =
GeneralSolution + CValues[]*E^(Eigen[[1, i]]*t)*Eigen[[2, i]], i++]
Which seems to work, and is equivalent to Sum(c*v*e^(\(lambda)*t)), where c's are the constant coefficients for a particular sol-n, {v,\lamdba} is the corresponding eigenpair, and t is time. I'm pretty sure this was the way we learned in intro ode, which is equivalent to the matrix exponential (which I did before, but crashed sometime, for some reason)
