Maxwell's Eq in Complex Form: Why Is It Not Popular?
  • Thread starter Swapnil
  • Tags
    Form Max
In summary: The conversation discusses the different forms of Maxwell's equations, particularly the complex form using the vector \vec{M}. This form allows for easier calculation and manipulation, and has some interesting properties such as being proportional to electromagnetic energy density. However, some argue that the traditional form is more popular due to the separation of the equations for the electric and magnetic fields. There is also a compact form using the Faraday tensor, which has a simple physical interpretation in the study of relativity. Another form is presented using spinors, showing similarities to the Dirac equation.
Swapnil
459
I recently read that Maxwell's equations can be written in a more concise form as the following:
[tex]\nabla\times\vec{M} = \frac{-i}{c}\frac{\partial\vec{M}}{\partial t}[/tex]
[tex]\nabla\cdot\vec{M} = 0[/tex]
where [tex]\vec{M} = c\vec{B} + i\vec{E}[/tex].
Why is this form not popular?
What does it allow you to do that you can't do with the regular form?
Its easy to remember for one. And I guess it can simplify certain calculations because now you would be able to compress everything into fewer equations...
Ok, that makes sense. BTW, these aren't the full eqns, they're only valid in source-free regions. Maybe that's why they aren't popular.
That's easy to fix -- just apply the ordinary Maxwell's equations to compute what Div M and Curl M should be. I think it just amounts to adding in (electric) current density to the first and (electric) charge density to the second.
P.S. have you tried computing [itex]M \cdot M^*[/itex] and [itex]M \times M^*[/itex]?
I tried but I it doesn't make sense. How can you dot two imaginary numbers? Or cross them for that matter? How is such a thing defined?
[tex]\vec{M}\cdot\vec{M}^* = (c\vec{B} + i\vec{E})\cdot(c\vec{B} - i\vec{E}) = ??[/tex]
You're not crossing and dotting imaginary numbers -- you're crossing and dotting complex vectors. It's defined in exactly the same way as you would for real vectors. In particular, it satisfies the distributive law, and you can always pull out scalar factors. (Any complex number is a scalar!)
I see. So basically,
[tex]\vec{M}\cdot\vec{M}^* = (c\vec{B} + i\vec{E})\cdot(c\vec{B} - i\vec{E})[/tex]
[tex] = c\vec{B}\cdot(c\vec{B} - i\vec{E}) + i\vec{E}\cdot(c\vec{B} - i\vec{E}) [/tex]
[tex] = c^2 (\vec{B}\cdot\vec{B}) - ic(\vec{B}\cdot\vec{E}) + ic(\vec{E}\cdot\vec{B}) - i^2(\vec{E}\cdot\vec{E}) = c^2{||\vec{B}||}^2 + {||\vec{E}||}^2[/tex]
So what's the significance of this number?
It's proportional to electromagnetic energy density!
The cross product I mentioned turns out to be proportional to electromagnetic power flux.
I guess the real reason is that, while E and B fields are known to be different manifestations of really the same object (nicely represented by the complex 3-vector M, or alternatively by the electromagnetic field tensor), they are measured in very different ways and have radically different effects (in a particular frame). So it makes sense to separate out the equations for B and E fields as it may sometimes cloud the problem. E.g. in a simple use of Ampere's law/Gauss' law, is there a need for the complex form of the equations?
In any case, I prefer using the field tensor to tidy up and condense equations. This is mainly because the transformation rules of the field tensor are glaringly obvious, whereas they are fairly complicated in the case of the complex 3-vector. Furthermore, useful invariants are also easily obtained. And things like equations of motion of a charged particle in an EM field is easily written with regard to the field tensor as opposed to the complex 3-vector M (as far as I can see).
Swapn,
Remember that the most concise form is the following:
d F = 0
d*F = *J
where
F is the Faraday tensor,
*F is the dual of F,
J is the current quadrivector,
d is the exterior derivative
This form is very popular too in the study of relativity.
Moreover, this compact system has a simple physical interpretation (see MTW for full details).
Michel
d F = 0
d*F = *J
where
Thanks Michel and masudr. I did not know that before.
Here's is a little more general form of the Maxwell's equations in complex form:
[tex]\nabla\cdot\vec{M} = \frac{i\rho}{\epsilon_0}[/tex]
[tex]\nabla\times\vec{M} = c\mu_0\vec{J} + \frac{-i}{c}\frac{\partial\vec{M}}{\partial t}[/tex]
I am pretty sure this is correct.
For either of the forms that Swapnil gave (i.e. with or without sources), what would the Lorentz force equation look like? I mean the one that normally looks like F = q(E + v X B)? I guess it'd be some sort of F=q*f(M), but ... :confused: ?
I don't see any particular advantages using this "complex vectors"... the main thing about using complex number is the Euler's equation (as far as what I've learnt)
[tex]e^{ix}=\cos x+i\sin x[/tex]
unless you can think of an analogous equation for M... hmmm
d F = 0
d*F = *J
Nicer and more compact form of Maxwell's equations can be found as follow;
Use
[tex]M_{0}=0[/tex]
[tex]M_{i}=H_{i} +i E_{i}[/tex]
to define the 2-component (column) objects;
[tex]\Psi_{1}= (M_{0}+M_{3} , M_{1}+iM_{2})^{T}[/tex]
[tex]\Psi_{2}= (M_{1}-iM_{2} , M_{0}-M_{3})^T[/tex]
Also, write
[tex]\mathcal{J}_{1}= 4\pi (\rho +j_{3} , j_{1}+ij_{2})^T[/tex]
[tex]\mathcal{J}_{2}= 4\pi (j_{1}-ij_{2} ,\rho - j_{3})^T[/tex]
Then you could write the 8 real Maxwell equations in the spinor form (two 2-componen spinor equation):
[tex]i \sigma_{\mu} \partial^{\mu} \Psi_{a} = \mathcal{J}_{a}[/tex]
Notice the similarity with the Dirac equation in its 2-component form.
Also, for [tex]\mathcal{J}_{a}=0[/tex]
the equation reduces to Weyl's equation for massless "fermion" field.
regards
sam
1. Why is Maxwell's equation in complex form not commonly used?
Maxwell's equations in complex form are not commonly used because they are more complex and difficult to understand compared to the simpler, more intuitive vector form. Additionally, the vector form is more widely applicable and easier to manipulate mathematically.
2. What is the advantage of using Maxwell's equations in complex form?
The advantage of using Maxwell's equations in complex form is that they provide a more accurate and complete representation of electromagnetic phenomena. They also allow for more advanced mathematical analysis and modeling of electromagnetic systems.
3. Are there any specific applications where Maxwell's equations in complex form are commonly used?
Maxwell's equations in complex form are commonly used in the fields of optics, plasma physics, and quantum mechanics, where the vector form may not accurately describe the behavior of electromagnetic waves. They are also used in the design and analysis of microwave and radio frequency systems.
4. Can Maxwell's equations in complex form be converted to the vector form?
Yes, Maxwell's equations in complex form can be converted to the vector form using mathematical operations known as the real and imaginary parts. This allows for easier understanding and manipulation of the equations.
5. Are there any limitations to using Maxwell's equations in complex form?
One limitation of using Maxwell's equations in complex form is that they may not accurately describe transient phenomena or systems with nonlinear behavior. Thus, the vector form may still be preferred in these situations.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
