Maximizing Speed with Front and Back Wheel Ratio in a Spring Powered Dragster
  • Thread starter Thread starter klkc
    Spring
The discussion revolves around the design considerations for a spring-powered dragster, specifically focusing on the relationship between wheel size, inertia, and angular acceleration. Participants explore how the front and back wheel ratios might influence performance and speed.
  • Participants inquire about equations relating inertia to angular acceleration and the implications of wheel size on performance. Questions arise regarding the impact of front and back wheel ratios on speed and the conditions for wheel slipping.
The discussion is ongoing, with various interpretations being explored. Some participants provide equations and insights into moment of inertia and torque, while others express confusion about the relationships between wheel sizes and performance metrics.
Participants are navigating assumptions about inertia, torque, and the effects of wheel size on friction and acceleration. There is a mention of the stiffness of the spring and its relevance to the design, but specific values or outcomes are not concluded.
klkc
1. i am in my first year of my engineering course, now doing a project that involves designing, building and testing a spring powered dragster. i am charged with the design of the wheels. so far i know that inertia is proportional to the square of the radius (k and m almost constant) and the spring has stiffness of 2.01 N/mm.
what equations are there that relate inertia to angular acceleration, how does the ratio front wheel ratio: back wheel ratios (apart from shifting the weight distibution), and what would k be for a wheel (im thinking 6 spokes equally spaced)?
thanks
You mean moment of inertia? [tex]\tau=I\alpha[/tex] (that is, torque, or moment, is equal to the moment of inertia multiplied by the angular acceleration)
That isn't a complete question.
k, as in the radius of gyration? [tex]k=\sqrt{\frac{I}{m}}[/tex]
You can either perform the integrals yourself or look up the moments of inertia for the objects that make up a wheel (and just sum them together).
what i meant was does the choice of the size of the front wheel affect the choice of the size of the back wheels if one wants to maximise speed and i also would like to know how they are related. also kinda confused. i think in order for the wheel not to slip the moments around the centra of it must balance but then there would be no angular acceleration as there is no unbalanced moment.
The wheels slipping depends on the horizontal force exerted on the ground and the maximum static friction force the ground can supply.
I'm not sure. I suppose the rear wheels on dragsters are larger because that would increase the surface area in contact with the ground (which would increase the maximum frictional force), although this only makes sense if the rear wheels are the only wheels with a torque applied to them. A larger wheel would also probably mean a larger moment of inertia, however, which would mean a slower start but would also mean it would have more angular momentum.
  • · Replies 16 ·
9K
14K
19K
  • · Replies 129 ·
82K
  • · Replies 85 ·
54K
