Maximizing Toboggan Speed: Calculating Slope and Adjusting for Weight and Dips
  • Context: Undergrad
  • Thread starter Thread starter zoltar
    Speed
The discussion revolves around calculating the slope of a hill required for a toboggan to reach a speed of 40 mph, considering varying weights of the toboggan and adjustments for dips in the hill. The scope includes theoretical calculations, empirical considerations, and the impact of friction and air resistance.
  • One participant seeks a straightforward method to calculate the necessary slope for different toboggan weights to achieve 40 mph.
  • Another participant asserts that weight does not affect acceleration due to gravity, suggesting that the slope calculation should not depend on weight.
  • A different participant highlights that factors such as friction between the toboggan and snow, as well as air resistance, complicate the calculation, indicating that no simple formula exists.
  • One participant provides a formula based on energy conservation principles, calculating a height change of 209 m needed to reach the target speed, while noting that this is an approximation and depends on the absence of air resistance and friction.
  • Further clarification is offered regarding unit conversions and the proportionality of kinetic energy change to the square of the change in velocity, suggesting adjustments to the initial calculations.
Participants express differing views on the impact of weight and external factors like friction and air resistance on the calculations. There is no consensus on a single method or formula to determine the required slope for the toboggan.
The discussion reveals limitations in the assumptions made, particularly regarding the neglect of friction and air resistance, and the dependence on specific conditions such as snow quality and toboggan design.
zoltar
i need help, i need to calculate the slope of a hill to reach 40mph on a toboggan? how do i do this with a fluctuating toboggan weight...meaning what is the slope i require for different weights? also how would i adjust for dips in the hill?
can anyone help? this is not might area and would appreciate something simple that i could use.
thanks!
Welcome to PF!
Hi zoltar ! Welcome to PF! :smile:
Acceleration is what matters, and as Galileo proved (on a slope, by the way), all weights have the same acceleration under gravity.
So the weight doesn't matter. :smile:
Not following you … what sort of dips? :confused:
It's not so simple.
It depends on the friction of the toboggan on the snow - which depends on the design of the toboggan, and the quality and temperature of the snow.
And then it also depends on the air resistance of the toboggan and its rider(s).
So there isn't a simple formula that will give the right answer. You're probably better conducting an empirical experiment (trying it out for real, and seeing what results you get).
It is relatively simple if you assume no air resistance/friction etc. But it will depend on how much space you have and how quickly you want to reach your target speed.
[tex]\frac{1}{2}m (\Delta v)^{2} = mg \Delta h[/tex] (kinetic energy gained = gravitational potential energy lost)
[tex]\Delta h[/tex] [tex]= \frac{v^{2}}{2g}[/tex]
[tex]= \frac{(40*1.6)^{2}}{2*9.8} = 209m[/tex]
So you will need a height change of 209m to achieve 40mph. Now you can calculate, using right-angled-trigonometry and knowledge of the space available, the angles you'd need to achieve this. Note this is just an approximation of course.
One should be careful with units here. The numerator would have units if (km/hr)2 and the denominator units of m/s2, so one must apply conversion factors 3600 s/hr and 1000 m/km. In doing so, the above expression becomes,
[tex]= \frac{(40*1.6)^{2}}{2*9.8*3.6^2} = 209 / (3.6)^2 m = 16.1 m[/tex]
Also, the change in kinetic energy is proportional to [tex]\Delta(v^2)[/tex], not [tex](\Delta{v})^2[/tex].
11K
  • · Replies 28 ·
