Example of Maximum Principle for Heat Equation PDEs
  • Thread starter Thread starter aa1174
    Maximum Principle
aa1174
can you please help me give an example of an illustration of the maximum principle of the heat equation (using partial differential equations)
thank you..
em..how about a trivial example that the heat equation reduces to the Laplace equation, and as we know every solution to Laplace equation satisfies maximum principle.
thank you. how about other examples?
do you want a real-life example or an actual math problem that uses the maximum principle?
an actual math problem.. thank you..
Check it out: http://www.math.ucsb.edu/~grigoryan/124A/lecs/lec8.pdf
It's great. It has the proof of the maximum principle (its weaker form) in detail. I think you should find it useful.
Honestly, there are plenty of problems online and in textbooks (you can use google books). Here is one I found in mine:
Consider the diffusion equation u_t = u_{xx} in (0 < x < 1, 0 < t < \infty) with u(0, t) =u(1, t) =0 and u(x, 0) =4x(1 - x).
(a) Show that 0 < u(x,t) < 1 for all t>0 and 0<x< 1.
(b) Show that u(x, t) = u(1 - x, t) for all t \geq 0 and 0 \leq X \leq 1.
(c) Use the energy method to show that \int u^2 dx is a strictly decreasing function of t.
parts a and b emphasize more on the maximum principle.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
