Finding Absolute Extrema for a Rational Function with Imaginary Solutions
  • Thread starter Thread starter QuarkCharmer
QuarkCharmer
Find the absolute max/min of the function on it's interval.
f(x)=\frac{x^2-4}{x^2+4}
Interval: [-4,4]
I basically want to find all the critical points, so I set the denominator to zero and found a critical point to be where x = 2i, and x = -2i.
Then I took the derivative of the function as so:
f'(x) = \frac{2x(x^2+4)-2x(x^2-4)}{(x^2+4)^2}
Setting the numerator to zero should find where the derivative is equal to zero, but that expands out to this:
2x^3+8x-2x^3+8x
Which is basically zero anyway. I was going to try to factor out something from the numerator and denominator (if possible) to cancel it out so I could get something, but I thought I would lose solutions doing that. So here is where I am confused? I tried graphing it, thinking that it would just return the line y=0, but my TI-89 just says "not a function or program, error"?
edit: fixed
Hint Hint: 2 negatives make a positive. Look at your expansion again :)
Ah yeah. Thanks! So the other critical point is 0 then.
Your algebra is faulty. The x terms don't cancel. And you probably don't care about imaginary solution in the denominator.
2x^3+8x-2x^3+8x=0
from the numerator, works out to be:
16x=0
x=0
I was not sure what to do with the imaginary solutions, essentially the only critical point found is at x=0 then I would imagine. Leaving me to check the endpoints and x=0 so find the absolutes correct?
QuarkCharmer said:
2x^3+8x-2x^3+8x=0
16x=0
x=0
Correct. The imaginary solutions are irrelevant. They aren't in the real interval [-4,4].
Alright, I think I got it now. This was the only one in the set of problems that had the possibility of an imaginary solution, and I really wasn't sure if that counted or not.
Thanks for the help.
