Maxwell's equations from U(1) symmetry
Thoros
I understand that one is able to derive the inhomogenuous pair of Maxwell's equations from varying the field strength tensor Lagrangian.
Now implying the U(1) gauge invariance, how is one led to the Maxwell's equations?
Thoros said:
I understand that one is able to derive the inhomogenuous pair of Maxwell's equations from varying the field strength tensor Lagrangian [...]
No, the homogenous pair results that way. To get the inhomogenous ones you need to add in a term for coupling to (charged) matter.
[...] Now implying the U(1) gauge invariance, how is one led to the Maxwell's equations?
From a geometric perspective, U(1) is embedded in the field.
Sorry about that, you are right about the lagrangian.
Could you give me a few hints on how to do it explicitly or is this already enough to manage with the task of deriving the equations?
Thanks.
Alright so i reached the point where you get an interaction term in the lagrangian density leading to the inhomogenuous pair of Maxwell's equations.
But to me the intrudiction of a covariant derivative is a little confusing. It seems perfectly reasonable to require that physics stay the same under U(1) symmetry. But adding the vector potential and simply implying an ad hoc transformation rule seems unjustifiable. Also, why do we have to add the elementary charge and planks constant to it? Is this required from dimensional analysis?
And from the Wikipedia article i understand, that the homogenuous pair still only arises from the same old field tensor Lagrangian.
Can anyone clear it up for me?
Thanks.
It is only justified by the fact that we end up with a theory that agrees with experiment. If gauge theories did not agree with experiment, only mathematicians (and not physicists) would care about them.
You cannot derive Maxwell's equations (or any other physical theory) from pure logic. All you can do is find out which theories agree with experiment, and then subsequently notice any cool mathematical features that they might happen to have (such as gauge invariance).
Actually, that's a little too strong. Quantum electrodynamics is an abelian gauge theory, and by 1950 or so it was well established that it agreed with experiment. This success motivated theoretical investigations of nonabelian gauge theories, which ultimately turned out to be relevant for the description of both strong nuclear and weak nuclear interactions (though it took a long time and travel down several wrong roads before the precise connection was understood).
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
